Old 06-29-2009, 10:54 PM   #1
Default Trane XE 1000 Fan Problem
I have a TRANE XE 1000 (TWR042C100B3); installed in 2002. Recently it started making squeaking sounds that made me think the bearings in the fan motor might be wearing out. Today the fan shut down while the system was running.
Shut off the power and let it rest for a while. Poked a fan blade with sliver of wood. It seemed to spin ok. Powered up and the fan and the compressor was running. 10 minutes later and the fan had stopped. There was quite a bit of heat coming up from the coil and compressor area. Shut the power off. Tried it a gain a half hour later; heard a switch click (not sure which switch), the fan did not start, and I think the compressor started. Since the fan did not start, shut it off and repeated turning it on with the same result. Checking behind the power panel, nothing looked out of the ordinary. The green diode on the circuit board was blinking.
Is there a way to check if the motor is the cause? If I am putting the multi meter on the motor leads, what about the charge on the capacitors?
What else should I check?
Thank you,
Flathead64 is offline   Reply With Quote
Old 06-29-2009, 11:00 PM   #2
Master Plumber/Mechanical
I'm betting that the fan capacitor is going bad
Plumber101 is online now   Reply With Quote
Old 06-29-2009, 11:00 PM   #3
hvaclover's Avatar
Bearings. Need new motor. Change the cap too.
Just slow, not stupid.
hvaclover is offline   Reply With Quote
Old 06-29-2009, 11:12 PM   #4
Yoyizit's Avatar
Squeak = bad bearings.
You can check the cap with your meter, a 1 megohm resistor and a 9v battery.
Changing the 7 yr. old cap is probably good practice or it really has failed.
Yoyizit is online now   Reply With Quote
Old 06-29-2009, 11:16 PM   #5
It is the bearings. Grab the shaft of the motor and move it back and forth (side to side). If you feel any free play, it is the bearings and the fan should be replaced. As stated before, you should always replace the cap with a new motor.
bluefitness is offline   Reply With Quote
Old 06-30-2009, 12:53 AM   #6
How should I discharge the the enegy in the capacitor before disconnecting the the four wires?
Old 06-30-2009, 01:00 AM   #7
hvaclover's Avatar
You don't. The are not strong enough to poke you.
I think a start cap was what was being referred to earlier. They have a much stronger charge than the cap that you have. Just remember where the wire go that you pull off the cap.
Old 06-30-2009, 01:37 AM   #8
There is the Start Capacitor (in the drawing it is in the "Start Kit") that is for the compressor and there is the "Run Capacitor" It is tube shaped about 1.5 inches diameter and about 4 inches long. Two sets of terminals: one set feeds the fan motor the other the compressor. (I didn't write down the specifics on the capacitor. ) It is the Run Capacitor you are saying to replace, right?
If replacing the Run Cap, I don't need to discharge it before disconnecting the wires and removing the capacitor, right?
Thank you,
- Flathead64
Old 06-30-2009, 10:06 AM   #9
hvaclover's Avatar
Thank you,
- Flathead64
Correct. Your run cap is most likely a five MFD.
Old 06-30-2009, 12:54 PM   #10
An old Tradesmen
Even a 5 uF run cap can give you a good jolt.
Old 06-30-2009, 02:44 PM   #11
Yoyizit's Avatar
More than 1 joule can be fatal. With 5 uF you'd need 800v on it to get to this level of energy.
Most of the time you have less than 300v on them so I think most of the time these could give you some level of non-fatal shock.
Old 06-30-2009, 07:22 PM   #12
hvaclover's Avatar
Never been poked ever by 5mfd.
Old 06-30-2009, 07:27 PM   #13
An old Tradesmen
Got it a couple times already.
5s aren't bad. But, they wake you up when its late at night.
Old 06-30-2009, 07:28 PM   #14
Yoyizit's Avatar
According to your avatar, you are one of the Undead. Everybody knows they're immune to shocks.
Old 06-30-2009, 07:32 PM   #15
hvaclover's Avatar
LOL..smart ass.
More On This Topic
The thermostat on your wall that controls your HVAC system is the key to your comfort. Knowing how it interfaces with your heating and air conditioning system can help you stay comfortable during long, cold winters and hot, sweltering summers. A key part... Read More »
How to Pick Ceiling Fans
How to Pick Ceiling Fans by Expert Village
Hello! My name is Adolph Ramirez from Tampa, Florida and on behalf of Expert Village, this is how to install a ceiling fan. Some of the things that you need to consider before selecting a new fan for your home are fan size height from the ceiling, blades... Read More »
Hi! I'm Chad Smith and I'm a State Certified Journeyman and Wireman; that's an electrician. I'm here today with expertvillage.com and we are going to hang a new ceiling fan. Now this project is very simple. It is not as hard as it looks. I know most of... Read More »
Hi! I'm Chad Smith and I'm a State Certified Journeyman wireman. Basically, I'm an electrician. I'm here with expertvillage.com today. The first step that you are going to want to take when you are doing anything with electrical work is you are going to... Read More »
Hi this is Jon on behalf of Expert Village in this video clip I'll be talking about electrical requirements and air compressors. First off the cord is the life line of your air compressor so you want to make sure it's kept in good condition and addition... Read More »
new install of Trane XL15i nind HVAC 23 06-12-2009 09:01 PM
Need some friendly advice-- Coleman/York v. Trane biggerdaddynj HVAC 2 05-22-2009 09:40 PM
Stymied by window leakage problem. Matth3w General Discussion 5 06-11-2008 08:26 PM
Trane XL1200 - Outdoor Unit Problem snifred81 HVAC 2 06-02-2008 08:19 AM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 03:51 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
