Trane XE 1000 - Fan Does Not Turn On - HVAC - DIY Chatroom Home Improvement Forum
Old 06-24-2011, 01:46 AM   #1
Unhappy
Trane XE 1000 - Fan does not turn on
Hello,
I have read most of old threads, but I could not find a thread contains exact same problem as mine.
My A/C unit is Trane XE 1000. The outdoor unit make a noise like the compressor is running, but the fan does not turn on.
So, I gave the fan blades a push by a stick and the fan moves freely by pushing, but not by the unit. I decided to check the capacitor first, so I took the capacitor(7.5uf, 45uf, 440VAC) off and measured by the multimeter. It says 7.52uf and 45.72uf. Also, the capacitor has no bulging. Do I still need to try changing the capacitor, or need to check the motor? or something else?? I am not a good tech, but I want to try to fix it by myself first. Please help. Thanks.
collman is offline   Reply With Quote
The Following User Says Thank You to collman For This Useful Post:
charles B ALBER (07-29-2012)
Old 06-24-2011, 05:47 AM   #2
An old Tradesmen
Rewards Points: 6,116
OHM out the motor windings.
Old 06-24-2011, 12:57 PM   #3
Question
Does it mean I need to get an new motor?
Thank for your reply.
Old 06-24-2011, 01:13 PM   #4
Rewards Points: 1,528
Try:
http://www.wikihow.com/Check-an-Electric-Motor
Also, make sure no electricity is going to the system (pull fuses/turn off all involved circuit breakers) or you could get hurt. If unsure, get a pro!!!!!!!!!!!
bob22 is offline   Reply With Quote
Old 06-24-2011, 06:12 PM   #5
Thank you for the reply. Right, I need a new motor.
I have called several local stores, they don't sell to the public.
Please let me know where can I buy a new motor?
Part# MOT3125
Old 06-24-2011, 06:25 PM   #6
JJboy's Avatar
Part# MOT3125
I replaced one yesterday. Here is the replacement #
S88-501 ( 1860 48FR 1/4HP )
Johntone Supply
http://www.johnstonesupply.com/store...odS88-501.html
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 06-24-2011, 07:31 PM   #7
I have already called them, they won't sell one to me.
Old 06-24-2011, 07:44 PM   #8
JJboy's Avatar
http://cgi.ebay.com/Emerson-1860-1-4...item2301f06c12
http://cgi.ebay.com/Q-E-1-4HP-CONDEN...item3cb9355613
Old 06-24-2011, 08:27 PM   #9
vln
Underwriter
They won't sell to you? Darn, I was going to buy some supplies from them.
vln is offline   Reply With Quote
Old 06-24-2011, 10:46 PM   #10
I'm going to change the motor only. But, just to make sure, do I need to change the capacitor together when I change the motor?
Thanks.
Old 06-24-2011, 11:27 PM   #11
Hi JJboy,
I did not get the motor yet. My motor is 7.50/370. Emerson 1860 is 5.0/370.
Is it ok to get it?
Old 06-24-2011, 11:49 PM   #12
JJboy's Avatar
Yes, change the capacitor
Old 06-24-2011, 11:58 PM   #13
My current dual capacitor is 7.5uf/45uf and it is good condition. Do you mean I get a Emerson 1860 and order a new capacitor with 5.0uf/45uf? If I order a motor with 7.5, can I use my current capacitor?
Thanks.
Old 06-25-2011, 12:09 AM   #14
JJboy's Avatar
You can isolate 7.5 and install 5 or buy dual 45/5
http://stores.directhvacsupply.com/-...Mfd/Detail.bok
Old 06-25-2011, 05:39 AM   #15
An old Tradesmen
New motor new capacitor weather the old one is good or not.
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 11:40 AM
Need some friendly advice-- Coleman/York v. Trane biggerdaddynj HVAC 3 05-09-2010 11:46 AM
new install of Trane XL15i nind HVAC 32 01-30-2010 01:59 PM
Humid - Switched Trane xl1200 AC for a Payne HP - now very Humid dagrappler HVAC 1 06-11-2007 01:16 PM
Faucet won't turn off etiger Plumbing 1 08-31-2005 03:46 AM
