Trane Xe 1000 Condensoer Fan Running In Reverse - HVAC - DIY Chatroom Home Improvement Forum
Old 11-29-2010, 03:10 PM   #1
Question
Trane Xe 1000 condensoer fan running in reverse
I have an Trane XE 1000 TWR048D100A1, the problem is last week when i walked by i noticed the fan has decided to run in reverse. It was installed in 2000 and has always ran fine and in the correct direction. I have seen post as to the cause etc. run capacitor, motor bad,.....so what do ya think? I switched the capacitor wire with the other hot wire to change polarity and it ran in the right direction but at a reduced speed to my recollection. It also has 2 flashes/sec on LED, is this related. The unit will heat and cool depending on the selection made......scratching my head guys! Thanks
jmarkt is offline   Reply With Quote
Old 11-29-2010, 04:39 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 396
Replace the capacitor with a new one.
Old 11-29-2010, 05:44 PM   #3
An old Tradesmen
Rewards Points: 8,204
And put the wires back the way they were.
Old 11-30-2010, 09:06 AM   #4
Thanks, new capacitor on the way!!!
Old 12-06-2010, 10:38 AM   #5
Thanks men, the capacitor has solved my problem, fan is again running in the right direction!
Old 12-06-2010, 01:28 PM   #6
too bad he shortened the life on the fan.
hvaclover is offline   Reply With Quote
Old 12-06-2010, 02:03 PM   #7
That's no problem either, got a brand new fan motor sitting in the shop, the old ones already 11 years old so i ordered one with the capacitor, better to have one and not need it than to need one and not have it!!
Old 12-06-2010, 03:40 PM   #8
Always replace motor when you replace your cap. Unless it was found to be low not drained u should check the cap.yearly and replace when it starts loosing it mf
Bill
Hixheat1 is offline   Reply With Quote
Old 12-06-2010, 05:39 PM   #9
Was still an unwise and unadvised action moving the cap wires. For that you get the HALL OF SHAME AWARD[IMG]file:///C:/DOCUME%7E1/John/LOCALS%7E1/Temp/moz-screenshot.png[/IMG]
Trane XE80 Furnace fan won't stop running Luv2Auction HVAC 2 01-07-2013 09:05 AM
Trane condensing unit keeps running fastback4 HVAC 1 06-08-2010 06:49 PM
XE 1000 Noise from the compressor but not running berr3555 HVAC 0 02-08-2010 06:15 PM
Trane Furnace Blower Running Nearly Continuously stephensandlin HVAC 3 01-03-2010 01:21 AM
Trane XE 1000 Fan Problem Flathead64 HVAC 15 07-01-2009 09:08 PM
