Trane XE 1000 - HVAC - DIY Chatroom Home Improvement Forum
Old 07-28-2012, 04:13 PM   #1
Trane XE 1000
Today Inoticed warm air blowing, so i looked a the outside airconditioner and noticed the fam would run a minute or 2 and then stop. Took it apart cleaned the coils with sray cleaner from lowes and oiled the fan. Looked at the capacitor and it looks good no buldge, put it back together and tried it again and again it stopped. Is it just a bad fan motor?
SSPEELMA is offline   Reply With Quote
Old 07-28-2012, 04:37 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
most likely it is a failing motor.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
sspeelman (07-28-2012)
Old 07-28-2012, 05:06 PM   #3
REP
Its most likely the motor,but I have had bad caps right out of the box.Also take a quick look at the contactor to make sure you don't have a crispy contact on that.
REP is offline   Reply With Quote
The Following User Says Thank You to REP For This Useful Post:
Old 07-28-2012, 05:39 PM   #4
Replacement Parts
Can I replace with this motor? Looks to be the same specs.
DAYTON Fan Motor, PSC, 1/4 HP, 1075, 208-230v, 48YZ
sspeelman is offline   Reply With Quote
Old 07-28-2012, 05:43 PM   #5
AKA HVACTECHFW
dont know, what is the model number of your a/c?
IT IS WHAT IT IS
Old 07-28-2012, 05:47 PM   #6
Thumbs up
Trane XE 1000 Emerson D151447P01 - I saw another post where someone else replaced theirs with this motor. Just wanted to make sure that it was kosher.
Old 07-28-2012, 05:55 PM   #7
AKA HVACTECHFW
WHAT IS THE MODEL OF YOUR A/C?................. Not the model of the motor.
IT IS WHAT IT IS
Old 07-28-2012, 06:03 PM   #8
Inside unit say trane XE 90 out side XE 1000 - How else would i tell?
Old 07-28-2012, 06:11 PM   #9
AKA HVACTECHFW
there is a plate on the unit outside with the model number and serial number..... and other important info.....I only need the model number
IT IS WHAT IT IS
Old 07-28-2012, 06:17 PM   #10
OK, found it ans some paperwork inside the electric panel - TTR060D100A0
Old 07-28-2012, 07:36 PM   #11
Grainger motor AO Smith
What abot an AO Smith? Will I need to change capacitor?
Motor Type
Permanent Split Capacitor
EnclosureTotally Enclosed Air-OverHP1/4Number of Speeds1Nameplate RPM1075NEMA/IEC Frame48YVoltage208-230Hz60Phase1Full Load Amps1.2-1.3MountingStudThermal ProtectionAutoInsulation ClassBService Factor1.0BearingsSleeveAmbient (C)60RotationCW/CCWLength Less Shaft (In.)5-3/16Shaft Dia. (In.)1/2Shaft Length (In.)5-5/8Body Dia. (In.)5-5/8Stud Quantity4Stud Pattern (In.)3 5/8 x 3 5/8Stud Size (In.)8-32 x 7/8, 8-32 x 9/16Shaft OrientationUp/DownLead Length (In.)37DutyContinuous Air-OverCapacitor Required2MDV4RPM Range1000-1380StandardsUL Recognized (E46412/E44549), CSA Certified (LR43341/LR4642)Mfr. Stock No.FSE1026SV1
Old 07-28-2012, 11:22 PM   #12
AKA HVACTECHFW
You need a MOT08914
1/4 HP, 200-230/60/1, 825 RPM, CCW, 48 FRAME, FLA 1.9, LRA 3.65, TYPE PSC, SLEEVE, 7.5 MFD CPT @ 370V. THIS MOTOR IS AN EMERSON MTR
IT IS WHAT IT IS
Old 07-29-2012, 05:35 AM   #13
HVAC Contractor
Rewards Points: 316
In regard to the two motors you indicated: You should NOT use either of those motors to replace the one in your system. Those are 1075 RPM motors and they will not work correctly in your system. If you're not sure which motor you should be using, then the best thing you can do is call a contractor to replace it for you, or purchase one through a Trane distributor if they'll sell you one.
scottmcd9999 is offline   Reply With Quote
Trane XE78 Furnace coupled with Trane 1000 AC JND HVAC 3 05-26-2012 03:53 PM
Compressor fan never turns off and never blows cold - Trane XE 1000 CZ DIY HVAC 9 04-05-2012 11:02 AM
Trane XE 1000 - Fan does not turn on collman HVAC 15 07-07-2011 03:23 PM
Trane XE 1000 (TWR060C100A2) repair wterlwms HVAC 3 09-27-2010 09:58 PM
Noisy Trane XE 1000 outdoor compressor CZ DIY HVAC 25 02-14-2010 07:46 AM
