Trane XB80 Burner Question - HVAC - DIY Chatroom Home Improvement Forum
Old 10-29-2012, 06:45 AM   #1
jjh
Trane XB80 burner question
My heater hasn't come on after turning it on for the first time this year. I get a constantly flashing LED - normal call for heat - and the ignitor comes on, but the burner won't light. The gas valve is on, and despite the burners not coming on, the unit runs then constantly and the LED blinks fast with no interruptions.
I'm down to the gas being the problem. The gas to the unit is working. Could it be clogged burners? If so - how to clean them? A faulty gas valve? Pressure switch?
Any help is appreciated to keep from calling the service guys out...but it's getting chilly.
jjh is offline   Reply With Quote
Old 10-29-2012, 07:07 AM   #2
jjh
Update
I don't hear a click right before the ignitor lights, making me think that either the gas valve isn't getting triggered to open, or is getting a signal sent but is not opening. Don't hear gas flowing and don't smell gas in the unit itself.
How can I tell which of these is going on? What is the fix? Something best left to the pros?
Old 10-29-2012, 11:04 AM   #3
JJboy's Avatar
use a voltimeter to check if you get 24v at the gas valve
Sent from my iPhone using DIY Forum
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 10-29-2012, 06:46 PM   #4
AKA HVACTECHFW
Rewards Points: 1,208
gas valve gets power AFTER the ignitor is glowing
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Tags
burners , gas furnace , malfunction , trane xb80
oil burner question tomthumb HVAC 2 10-14-2012 03:59 PM
main burner goes out after furnace running 10 -2 0 mins marion60 HVAC 4 11-02-2011 09:53 AM
Question about gas burner design darsunt HVAC 4 12-14-2008 01:37 PM
Oil Burner Question timlaptopm101 HVAC 2 05-31-2008 05:02 PM
Wood Burner Installation Question? fisher501 HVAC 1 12-22-2005 09:29 PM
