Trane X80 Popping C/B - HVAC - DIY Chatroom Home Improvement Forum
Old 12-05-2011, 07:01 AM   #1
Trane X80 popping C/B
I have a Trane X80 furnce that continues to pop the C/B. I let it sit for a few minutes and reset the C/B the unit begins to heat up, the burners ignite but then the unit pops the C/B - the fan never kicks in. Any ideas on the most likely cause?
Thanks for your help
Noheatnow is offline   Reply With Quote
Old 12-05-2011, 07:25 AM   #2
Sounds like a bad blower motor.
fitter1 is offline   Reply With Quote
The Following User Says Thank You to fitter1 For This Useful Post:
Noheatnow (12-05-2011)
Old 12-05-2011, 07:29 AM   #3
Originally Posted by Noheatnow View Post
I have a Trane X80 furnace that continues to pop the C/B. I let it sit for a few minutes and reset the C/B the unit begins to heat up, the burners ignite but then the unit pops the C/B - the fan never kicks in. Any ideas on the most likely cause?
What exactly do you mean by "popping" the circuit board?
harleyrider is offline   Reply With Quote
Old 12-05-2011, 07:56 AM   #4
The C/B for the unit, in the main house panel keeps popping (20A).
Old 12-05-2011, 03:53 PM   #5
Try to just turn on the fan an see what happens.
Hubcap626 is offline   Reply With Quote
Old 12-05-2011, 05:50 PM   #6
REP
There are very few things on a furnace that are line voltage and would cause the circut breaker to pop.
From your discription it sounds like the main blower motor but I would replace the capsitor first as it is cheap and easy to do.If that won't work then you'll be replacing the motor I guess.
REP is offline   Reply With Quote
Old 12-05-2011, 05:57 PM   #7
Rewards Points: 582
yes it sounds like you could have a direct short in motor just as it starts to come on,,,,check to see how long burnners are running before it trips....
Old 12-06-2011, 06:33 AM   #8
Thanks, I'll check the capcitor first
Old 12-06-2011, 08:37 AM   #9
HVAC Tech/ Browns Fan
It going to be bad motor for sure but need to pull back the board and look at the relays. Lot of times on that unit replays on the board burn up then take out the motor.
Tator1076 is offline   Reply With Quote
Old 12-06-2011, 08:45 AM   #10
biggles's Avatar
if you get a run in FAN/ON at the stat the lo/med lo winding might be shot...disconnect the motor plug then call it in again thru the heating
Old 12-06-2011, 08:05 PM   #11
How do I check to see if the board is bad or the relays on it?
The unit has gotten worse. It won't even light up now. I turned the thermostat heat off and tried to turn the fan on. Nothing happens. It just has a very low hummming sound.
The light comes on one time and then stays out.
Thanks for all your help!
Ruud vs Trane peter_holmes HVAC 23 07-28-2010 02:32 PM
Help me compare Trane heat pumps pls tomseeley HVAC 3 04-02-2010 05:54 PM
new install of Trane XL15i nind HVAC 32 01-30-2010 12:59 PM
Loud Popping Noises - when HVAC is Turned On. San Fran HVAC 2 01-04-2008 09:44 PM
Humid - Switched Trane xl1200 AC for a Payne HP - now very Humid dagrappler HVAC 1 06-11-2007 12:16 PM
