-   -   trane x19i heat pump (http://www.diychatroom.com/f17/trane-x19i-heat-pump-50447/)
MrSnapRon 08-07-2009 05:10 PM
I bought a trane x19i heat pump unit but all i want to use is the a\c compresor. I already have a carrier forced air unit with gas heater and a A coil for cooling . My question is what wires do i hook up on the trane to get this to work and which wires from my carrier unit need to hook up to the trane for this to work my old unit only used 2 wires from the forced air unit to turn on the compresor.
hvaclover 08-07-2009 06:57 PM
Yeah, that's a lot to go on.
JohnH1 08-07-2009 07:44 PM
This would be interesting to see operate. A 2 stage Heat pump that required a variable speed furnace used as A/C only with a mis-matched evap. Who knows if it is even the correct size? I DONT THINK SO!
beenthere 08-08-2009 06:31 AM
Hope you got it for a hundred bucks or less.
Are you going to use it as a single stage A/C.
Not enough info on what furnace you have.
Not to bust on Trane. But, you do know that the 19i, has no cheap parts when it breaks.
MrSnapRon 08-29-2009 04:42 AM
To all that replied to my post
Im glad i didnt listen to all your negitive anwsers lol because i hooked it up and it works perfect . Not one problem and for the guy who said just wait until it breaks down parts a real costly. Well so are parts for a bmw dosnt stop people from driving them.:thumbup:
beenthere 08-29-2009 05:37 AM
New BMW 's are bought completely assembled, with labor and part warranties.
What CFM is used for first stage.
What CFM is used for second stage.
What is the temp difference across the coil in both stages.
Is your TXV balance port, Or are you using a solenoid valve.
Inorder to know if it works perfectly, you would have to know these things.
beenthere 08-29-2009 05:39 AM
It runs.
Your happy.
The world goes on.
Yoyizit 08-29-2009 10:54 AM
Originally Posted by beenthere (Post 320849)
It runs.
Is its life being shortened?
beenthere 08-29-2009 02:17 PM
Without knnowing any of the operating readings. Can't say if it is or not for sure.
Running a 19i in first stage at the air flow second stage is suppose to have, is hard on the low stage compressor.
So, it could shorten the life of the low stage compressor.
Low stage is 50% capacity of second stage.
If its connected to a fixed metering device indoor coil. Then it will have liquid flood back, which can kill either or both compressosr.
Improper install/setup is worse for a 19i, then a 16i.
