Trane X1000 120/24VAC Transformer - HVAC - DIY Chatroom Home Improvement Forum
Old 01-29-2011, 07:46 PM   #1
Guy's I have a problem that I need your help with. The 120/24 VAC transformer primary side was shorted, so I first thought maybe something was wrong internally, but I found no shorts. I replaced the transformer today but check for any shorts before doing so, turn the heat on and everything was good, or so I thought. I went to the store and came back to find the new transformer shorted on the primary side too. I removed the transformer and checked with my multimeter and found nothing shorted. What could cause 2x transformers to go out? It was working fine, no problems. Any help is appreciated.
Slim2011 is offline   Reply With Quote
Old 01-29-2011, 07:51 PM   #2
HVAC / Plumbing
did you check for a short on the low voltage side. T. stat wires etc?
kenmac is offline   Reply With Quote
Old 01-29-2011, 07:54 PM   #3
No I did not. Before I left to go to the store after replacing the transformer it was working again. I will check to see if there is a short on the tstat
Old 01-29-2011, 07:58 PM   #4
HVAC / Plumbing
Low voltage short will burn out primary side of transformer
Old 01-29-2011, 08:00 PM   #5
I checked at the furnace terminals and no short. Could the tstat be going out and knock out the transformer?
Old 01-29-2011, 08:03 PM   #6
HVAC / Plumbing
how does your t.stat wire run. Crawl space, etc. it could be shorted any where
Old 01-29-2011, 08:04 PM   #7
The wires have not been touched, so I would hope there isn't a intermittent short with the wiring.
Old 01-29-2011, 08:05 PM   #8
From the basement up to the tstat...about 10 feet away.
Old 01-29-2011, 08:05 PM   #9
HVAC / Plumbing
mice love to chew on wires. That's why I asked if they ran through a crawl space.
Old 01-29-2011, 08:07 PM   #10
Course the tstat is dead right now with no power. Its a honey well about 8 years old. Would that be the only thing possible knocking out the transformer you think?
Old 01-29-2011, 08:10 PM   #11
The control board in the furnace was toggling the red light on and off like normal. Do you think I should buy a new control tstat and transformer, with the thought being the honey well control as the suspected component knock out the transformer?
Old 01-29-2011, 08:10 PM   #12
HVAC / Plumbing
The only thing That I have found that kills transformer primary is a short in L V is the x1000 a hp ? If so check the wires there
Old 01-29-2011, 08:17 PM   #13
I'm not sure what all is on the low voltage side? I know the transformer supplies the 24VAC to the board, but not sure what really goes on inside the board.
What about the wires outside to the compressor? Can I isolate the problem by turning on the air instead of the heat? Just a thought, trying to think of a way to find the problem.
Old 01-29-2011, 08:23 PM   #14
HVAC / Plumbing
Yoiu are just going to have to find your short. You can add a fuse to the LV to prevent future transformer burn outs. But, you have to locate the short
Old 01-29-2011, 08:26 PM   #15
Okay, thank you for your help. What size fuse do you suggest?
transformer failure in a Trane XE78 turtleescape HVAC 7 07-19-2010 07:34 PM
Unable to find out how to wire a dimmable light transformer Maleko Electrical 9 02-07-2010 01:07 AM
new install of Trane XL15i nind HVAC 32 01-30-2010 12:59 PM
How to install Aprilaire transformer? Studly HVAC 9 09-18-2009 09:44 AM
Comfortmaker RPJ - Bad Transformer? olgranddad HVAC 2 12-26-2008 11:10 AM
