Trane Unit- Fan Runs No Cooling - HVAC - DIY Chatroom Home Improvement Forum
Old 08-18-2013, 06:02 PM   #1
Rewards Points: 135
Hi. My outdoor unit is a Trane 2A7A3018-060A1000A. This is what is happening. Thermostat calls for cooling and indoor fan turns on. Compressor appears to start and run, but the condensing unit fan does not turn at all. If I give it a push, it slowly starts turning and building speed, but never gets to full velocity. This sounds like one of the capacitors (run?), perhaps the one that starts and runs the fan. Is replacing this capacitor the easy solution, or could it be that something else is causing the fan not run? Do I need to check that voltage is getting to the motor? If it is, then the problem probably is not enough current, right (bad run cap)?
smata67 is offline   Reply With Quote
Old 08-18-2013, 07:20 PM   #2
Rewards Points: 582
start with replacing capacitor....what you discribe sounds like cap..ben sr
The Following 2 Users Say Thank You to ben's plumbing For This Useful Post:
plummen (08-18-2013), smata67 (08-21-2013)
Old 08-18-2013, 07:22 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
Replace the capacitor.... and then recheck
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
The Following 3 Users Say Thank You to hvactech126 For This Useful Post:
ben's plumbing (08-18-2013), plummen (08-18-2013), smata67 (08-21-2013)
Old 08-18-2013, 08:14 PM   #4
Rewards Points: 135
What kind of store carries these? Electrical or HVAC supply house? I'm in Alexandria, VA.
Old 08-18-2013, 08:20 PM   #5
AKA HVACTECHFW
both, but hvac supply house should for sure have it.
IT IS WHAT IT IS
The Following User Says Thank You to hvactech126 For This Useful Post:
Old 08-19-2013, 07:49 AM   #6
biggles's Avatar
local Grainger
The Following User Says Thank You to biggles For This Useful Post:
Old 08-19-2013, 09:40 AM   #7
Rewards Points: 135
OK, we will start with the fun stuff. Took off the access panel and it looks like a mouse had made it a home at one time. What is baffling is there doesn't appear any way for it to get in. He ate a portion of my paperwork. I inspected all wires and it looks like he did not have a taste for insulation.
The cap is a GE 97F9899 35/5 440VAC (mexico), looks pretty standard, though it is short and stocky, unlike some of the replacements I am seeing. Diameter is 2.5" and height is 3". I will have to order it via Amazon, unless there is a chance Home Depot carries it. If there is and it is 370VAC, is that ok?
The direct replacement is about $45 + shipping. There are a few other models that can work, made in china, branded Aviditi and Amico (probably same thing) for significantly less and can ship overnight for $3.99 via Amazon Prime. Are these "good enough" or should I stick with a direct replacement? The GE lasted 6 years and I must say that I really don't run the a/c much (virginia), three months out of the year and we are mostly at work. I want to get the best part possible. I have 10" of vertical clearance, is that going to be a problem if I go the generic route? It has to be 2.5" diameter max.
I believe the wiring is as follows, as the existing capacitor is no longer labeled (update: I sanded the rust and the terminal labels have been revealed):
Brown: Fan
Thin Purple/Red: C
Orange/Orange: HERM
Aviditi
http://www.amazon.com/Aviditi-37AVI-...+5uf+capacitor
Amico
http://www.amazon.com/Amico-CBB65-Ro...+5uf+capacitor
Trane Unit- Fan Runs No Cooling-p8190786.jpg   Trane Unit- Fan Runs No Cooling-p8190787.jpg
Old 08-19-2013, 07:49 PM   #8
Rewards Points: 338
35/5 uf is the important part. 440VAC or 370VAC is fine. i always buy cheapos made in mexico and they last 5+ years.
i usually drive to johnstone's and buy it there, much cheaper than grainger's and you don't have to wait. some states/stores won't sell to the public, but i've never had a problem at the one near me here.
NitroNate is offline   Reply With Quote
The Following User Says Thank You to NitroNate For This Useful Post:
Old 08-19-2013, 07:51 PM   #9
AKA HVACTECHFW
no, you can NOT drop down in voltage rating.... The old was 440V and the replacement MUST be 440V.
IT IS WHAT IT IS
Old 08-19-2013, 08:32 PM   #10
Rewards Points: 135
I went ahead and just ordered off of Amazon, save me driving around town. Gonna be a hot one tomorrow, I may get complaints from the customer (the wife)...
The Following 2 Users Say Thank You to smata67 For This Useful Post:
ben's plumbing (08-20-2013), hvactech126 (08-19-2013)
Old 08-21-2013, 08:50 PM   #11
Rewards Points: 135
I have received and installed the Aviditi and unit is back on the job. The Aviditi is narrower and longer than the original GE, so I had to provide a spacer for it to fit on the mounting strap.
The Following User Says Thank You to smata67 For This Useful Post:
ben's plumbing (08-22-2013)
Old 08-23-2013, 11:19 AM   #12
Rewards Points: 77
Glad to hear you are back up and running. Here is a what I use when I change size or shape of run capacitors. It is very cheap and conforms to any size and shape. I purchase it in a 10' roll at the big box stores for a couple of bucks.
firedawgsatx is offline   Reply With Quote
Novice - AC cools only half house beads4me HVAC 27 07-25-2012 10:05 AM
AC unit not cooling or heating cchairez HVAC 3 02-22-2012 08:06 AM
Trane unit not switching from heat pump to Furnace when weather gets cold. Jimw606 HVAC 1 09-27-2011 04:03 PM
Cant figure out why the fan on my AC unit runs continueously markb1313 HVAC 1 07-05-2010 04:14 PM
Upstairs unit not heating or cooling JakAHearts HVAC 5 06-13-2010 09:22 PM
