Old 11-04-2010, 05:44 PM   #1
trane TUE060 furnace won't start
I was unable to find a similar problem in previous posts. I have a Trane TUE060 furnace. The furnace is not turning on when I set the temperature below the ambient temp. The AC functions properly and the blower fan runs when I switch to fan "on" mode (not heat mode). I'm getting an error code of three flashing red lights indicating pressure switch problem. The filter was just replaced. Based on other posts, I checked the tube behind the pressure switch and the exhaust fan turns freely. I also temporarily removed the exhaust tube to rule out blockage. I hope I didn't damage anything in doing so, but I also pushed back the plunger on the pressure switch with a screwdriver while holding the panel safety switch down. Still nothing. The unit doesn't seem to be doing anything (no hums or clicks...heard a click the first time I took the panel off and tried to start holding safety switch). Is it worth it to replace the switch ($45) before calling a professional? I don't have a voltmeter (and don't know how to use one anyway). Sidenote, the AC needed a charge last spring and there was considerable leakage of water down the unit when the ice melted off the coil (wonder if that damaged anything). Thanks in advance!
jkolo is offline   Reply With Quote
Old 11-04-2010, 05:49 PM   #2
HVAC / Plumbing
not going to be door switch if a/c works..I don't mean to sound harsh , but, If you don't know how to use vm. It's time for you to call someone.
kenmac is offline   Reply With Quote
Old 11-04-2010, 07:05 PM   #3
newtech's Avatar
[quote=jkolo;528640] . The furnace is not turning on when I set the temperature below the ambient temp.quote]
newtech is offline   Reply With Quote
Old 11-04-2010, 07:29 PM   #4
newtech's Avatar
Nice answer
Tags
gas furnace, no heat, pressure switch, trane
Oil Furnace Won't start ScottEW HVAC 0 10-05-2010 09:26 AM
Trane Furnace Blower Running Nearly Continuously stephensandlin HVAC 3 01-03-2010 02:21 AM
Trane xv80 furnace blower not working jim2138 HVAC 2 03-22-2008 05:55 PM
Trane xl-90 2 stage furnace problems ikon07 HVAC 5 03-14-2008 09:14 AM
Cozy Propane Furnace Start up Noise NJ Gimo HVAC 7 01-01-2007 11:06 AM
