Trane Tonnage - HVAC - DIY Chatroom Home Improvement Forum
Old 08-21-2011, 05:43 PM   #1
I'm Your Huckleberry
Rewards Points: 2,270
Trane Tonnage
What size is this?
Condenser model number: OAUA-402-D
Evaporator model number: TXH054A4HPA2
3.5 ton?
Doc Holliday is offline   Reply With Quote
Old 08-21-2011, 06:27 PM   #2
Rewards Points: 6,652
Here you go Doc
http://www1.eere.energy.gov/building...appendix_g.pdf It has info on all of the popular units.
http://www.brainerdcompressor.com/Model_Num.htm
http://rexonavn.com/download/manual/...2FjZGF0YS5wZGY
http://www.cee1.org/com/hecac/ac_tiers/mod_toc.htm
I am going to guess 4.5 ton.
Old 08-21-2011, 07:30 PM   #3
It's a 1755 sq ft home..?
Old 08-21-2011, 07:36 PM   #4
An old Tradesmen
Rewards Points: 6,098
You sure that a trane condenser.
Old 08-21-2011, 08:19 PM   #5
Looks like it is a old school trane or GE air handler for the Condenser.
Old 08-21-2011, 08:24 PM   #6
An old Tradesmen
I think you nailed it.
Old 08-21-2011, 08:46 PM   #7
I had to go back and look at one of the links. Found some stuff from hvac-talk, but nothing like the cheat sheets that I came across. I am going to say probably a 4 ton on the condenser. I am coming up with 33.5 btu's for the GE unit/air handler, doing the divide by 6 to see if divisible, then go back and divide the 402 by 12.
Old 08-21-2011, 09:45 PM   #8
Yes, 100% sure. I was there this Saturday and took down the make and numbers but wasn't sure what the tonnage was as it wasn't a straight ''42" or "36" in the model numbers of either the condenser or evap.
Over the phone the boss said it was a 3.5 ton but after this thread I'm more determined than ever to call Trane first thing in the morning.
Thanks guys, I'll take pics when I'm out there again for the new install (which will be Goodman) of the ancient beast.
Old 09-06-2011, 02:17 PM   #9
Cool
How soon.....
Doc,
How soon do you need the information? If it is indeed a Trane or even an old GE unit I should be able to pull up the information from the Trane E-Library tomorrow. Let me know.....TT1
TraneTech1 is offline   Reply With Quote
Old 09-06-2011, 03:58 PM   #10
That job was weeks ago. It turned out to be a four ton if I remember correctly. I thought I took pictures of it and posted it but thanks anyways. Always good to have insiders around.
Old 09-06-2011, 04:06 PM   #11
Again, if I remember correctly I called Aces which is the American Standard/Trane supply house and they told me the size.
Trane TCONT803 Tstat install ... on Trane XB14 system chaaalie HVAC 10 09-08-2011 07:56 AM
trane tonnage air man HVAC 3 04-13-2011 11:20 PM
Ruud vs Trane peter_holmes HVAC 23 07-28-2010 03:32 PM
new install of Trane XL15i nind HVAC 32 01-30-2010 01:59 PM
Humid - Switched Trane xl1200 AC for a Payne HP - now very Humid dagrappler HVAC 1 06-11-2007 01:16 PM
