-   -   Trane Tonnage (http://www.diychatroom.com/f17/trane-tonnage-114816/)
Doc Holliday 08-21-2011 04:43 PM
Trane Tonnage
What size is this?
Condenser model number: OAUA-402-D
Evaporator model number: TXH054A4HPA2
3.5 ton?
gregzoll 08-21-2011 05:27 PM
Here you go Doc
http://www1.eere.energy.gov/building...appendix_g.pdf It has info on all of the popular units.
http://www.brainerdcompressor.com/Model_Num.htm
http://rexonavn.com/download/manual/...2FjZGF0YS5wZGY
http://www.cee1.org/com/hecac/ac_tiers/mod_toc.htm
I am going to guess 4.5 ton.
Doc Holliday 08-21-2011 06:30 PM
It's a 1755 sq ft home..?
beenthere 08-21-2011 06:36 PM
You sure that a trane condenser.
gregzoll 08-21-2011 07:19 PM
Looks like it is a old school trane or GE air handler for the Condenser.
beenthere 08-21-2011 07:24 PM
I think you nailed it.
gregzoll 08-21-2011 07:46 PM
I had to go back and look at one of the links. Found some stuff from hvac-talk, but nothing like the cheat sheets that I came across. I am going to say probably a 4 ton on the condenser. I am coming up with 33.5 btu's for the GE unit/air handler, doing the divide by 6 to see if divisible, then go back and divide the 402 by 12.
Doc Holliday 08-21-2011 08:45 PM
Yes, 100% sure. I was there this Saturday and took down the make and numbers but wasn't sure what the tonnage was as it wasn't a straight ''42" or "36" in the model numbers of either the condenser or evap.
Over the phone the boss said it was a 3.5 ton but after this thread I'm more determined than ever to call Trane first thing in the morning.:thumbup:
Thanks guys, I'll take pics when I'm out there again for the new install (which will be Goodman) of the ancient beast.
TraneTech1 09-06-2011 01:17 PM
How soon.....
Doc,
How soon do you need the information? If it is indeed a Trane or even an old GE unit I should be able to pull up the information from the Trane E-Library tomorrow. Let me know.....TT1
Doc Holliday 09-06-2011 02:58 PM
That job was weeks ago. It turned out to be a four ton if I remember correctly. I thought I took pictures of it and posted it but thanks anyways. Always good to have insiders around. :thumbsup:
Doc Holliday 09-06-2011 03:06 PM
Again, if I remember correctly I called Aces which is the American Standard/Trane supply house and they told me the size.
http://i87.photobucket.com/albums/k1...822_133439.jpg
http://i87.photobucket.com/albums/k1...822_133459.jpg
