Trane Thermostate Install - HVAC - DIY Chatroom Home Improvement Forum
Old 07-14-2009, 08:54 PM   #1
I have a Trane AC and heat system with a heat pump and a propane backup for the heat. The system came with a Trane non-programmable digital thermostat. I wanted to upgrade to the XL800 thermostat so I purchased 2 new TCONT800 units on Ebay. The wiring doesn't match up and it appears I bought a controller that isn't compatible with my existing system.
Any advice as to whether or not I bought the wrong thermostat. If I do have the right one, I'd appreciate any advice on the wiring. If I bought the wrong won, any advice on which model to buy would be appreciated. Also, if I bought the wrong ones, I have 2 new thermostates for sale at a great price!!
Thanks for any and all advice.
Alan
alanv1811 is offline   Reply With Quote
Old 07-14-2009, 09:22 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
From what I am finding the stats you bought are one heat and one cool stats and won't work with your HP
You need 2 heat/2 cool Heat pump stat
Great for fishing weights????
This should work
http://cgi.ebay.com/Trane-XL802-TCON...3286.m20.l1116
Old 07-14-2009, 09:31 PM   #3
Yeah, Just what I thought. Thanks for the quick reply.
Tags
install , thermostat , trane , xl800
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
new install of Trane XL15i nind HVAC 32 01-30-2010 12:59 PM
Diagonal Hardwood Install Advice JDeFuria Flooring 7 06-29-2009 03:35 PM
Trane xv80 install draft exhaust wires on furnace biggiant HVAC 5 02-10-2009 06:50 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
