Trane Thermostat Replacement - HVAC - DIY Chatroom Home Improvement Forum
Old 03-02-2012, 02:23 PM   #1
Trane Thermostat replacement
I have a Trane thermostat with no model number on a conventional, gas/electric system. The stamp says the part no. is BAYSENS008B. It has two temperature control slides, red and blue that travel the same chanel, presumably one for heat one for cool.
There is no wire identification on the wires or on the connection points of the Trane thermostat. The wires go into a junction block numbered one through five, (1-5). By wire color the sequence is 1 = Red; 2 = White; 3 = Black; 4 = Brown; 5 = Green. I do know that typically the colors are related to the following designations Red=RH with jumper to RC (power); White=W (Heat Contactor); Black=C (Common); Brown=? Substitute for Yellow, (Cool Contactor); Green=G (Fan Relay); and I did connect them using those as the designations, I also swapped the Black and Brown with no change.
The wiring diagram cannot be found on-line to identify the corresponding connections for 1-5 for the Trane thermostat but it has to exist or the HVAC Engineer could not have installed it. Does anyone have the designations for the numbers on the wiring block.
I want to replace it with a programmable Hunter, model 44905 touch screen. I have installed it successfully on the front office system for my church replacing the York thermostat. We have the Trane system on the Sanctuary.
Maursce is offline   Reply With Quote
Old 03-02-2012, 02:45 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
You can not just replace that with a normal thermostat. Your thermostat is a reliatel zone stat. What is the model number of your package unit?
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 03-02-2012, 02:56 PM   #3
I have looked all over the cover and the backing plate the only thing I canfind is the letters on the circuit board that says ANC and the part number BAYSENS008B
Old 03-02-2012, 02:59 PM   #4
AKA HVACTECHFW
no, your package unit (hvac unit) outside.
IT IS WHAT IT IS
Old 03-02-2012, 03:05 PM   #5
Old 03-02-2012, 03:08 PM   #6
Trane Thermostat
unfortunately, it is raining/hailing right now and it is on the roof
Old 03-02-2012, 03:37 PM   #7
AKA HVACTECHFW
ok, when you can get to it. get the model number, also open the control panel and take a picture of the controls. you maybe able to switch to the elctro/mechanical control and use a normal thermostat. Your contractor did you no favors when they put a commercial control and setup in.
IT IS WHAT IT IS
Old 03-02-2012, 04:11 PM   #8
REP
I've replaced way more "Hunter" stats than I have installed.I hasve only installed Hunter stats that the customer bought and wanted me to install.
REP is offline   Reply With Quote
The Following User Says Thank You to REP For This Useful Post:
hvactech126 (03-02-2012)
Old 03-02-2012, 04:47 PM   #9
Originally Posted by REP View Post
I've replaced way more "Hunter" stats than I have installed.I have only installed Hunter stats that the customer bought and wanted me to install.
Amen! You buy cheap... you get cheap.
Old 03-02-2012, 05:01 PM   #10
An old Tradesmen
Rewards Points: 7,328
??? Its on a church Sanctuary.
Old 03-02-2012, 07:00 PM   #11
AKA HVACTECHFW
Totally missed that. Thanks!
IT IS WHAT IT IS
Old 11-08-2012, 04:42 PM   #12
So, I've had quite the time trying to get a normal thermostat to work with my roof Trane unit. Trane sensors are totally different (which I'm not a big fan of...). A normal thermostat won't just plug in--you have to get a "Trane Interface Board" first in order to change the interface to accept a normal thermostat. I went for a Venstar TIB-515, which made my unit work with a Hunter 7-day programmable thermostat for air conditioning, but now doesn't seem to work whatsoever with the heating function... I'm ready to chuck the dumb thing out the window and go for a 7-day programmable Trane temperature sensor. Anyone know if the new Trane sensors will work on a roof unit that ran off a BAYSENS008B?
jmoorm2 is offline   Reply With Quote
Old 11-08-2012, 06:22 PM   #13
if you have the unitary board in the unit you need a interface board if you have the relatel board you can use the low voltage connections
mrairflow is offline   Reply With Quote
Old 11-09-2012, 03:20 PM   #14
Rewards Points: 77
You need to just buy a conventional interface board, BAYCTHI001 I think, this takes Tranes proprietary (secret squirrel) wiring and turns it into the standard Y B G O , etc
Filtration / HVAC & Indoor Air Quality Solutions
AirstarFilters is offline   Reply With Quote
Old 11-09-2012, 09:39 PM   #15
Rewards Points: 616
yep interface board....throw that piece of crap Trane stat in a river...
carmon is offline   Reply With Quote
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 08:43 AM
Trane Xl 1200 5 ton Compressor Fan replacement opions needed spg112357 HVAC 35 01-04-2012 02:08 PM
Need help connecting Trane TZEMT400 Thermostat; no 'C' wire / 24VAC dinki HVAC 1 04-04-2011 06:28 PM
Ritetemp 6036 replacement thermostat deanrfire HVAC 0 01-15-2010 01:12 AM
Thermostat replacement bswest HVAC 5 04-14-2007 09:30 PM
