Trane Thermostat To Hunter Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 02-21-2013, 07:58 AM   #1
Trane thermostat to hunter thermostat
I am changing from the original trane thermostat to a hunter 44132. Using the wiring diagram provided, I have too many wires. I have:
r=red
t=brown
o=orange
g=light green
y=yellow
x2=black
w=white
u=dark green.
Can anyone provide any assistance? I thought programmable would be great, guess I was wrong.
Thanks, Tommy
tommy32539 is offline   Reply With Quote
Old 02-21-2013, 09:54 AM   #2
Houston204's Avatar
Rewards Points: 556
r=red = Rc and RH
t=brown = tape off
o=orange = O
g=light green = G
y=yellow = Y
x2=black = tape off
w=white = Aux/E
u=dark green = tape off
B = was a blue wire here? = C
You must also configure the new stat for heat pump operation with aux heat.
Setback temperature settings are not recommended in heat mode since the stat will bring on the expensive Aux heat to catch up.
Houston204 is offline   Reply With Quote
The Following 2 Users Say Thank You to Houston204 For This Useful Post:
jagans (02-21-2013), tommy32539 (02-21-2013)
Old 02-21-2013, 10:13 AM   #3
I really appreciate this. I will try it this evening.
Old 02-21-2013, 10:43 AM   #4
Roofmaster
Rewards Points: 2,172
Houston, you've Solved a Problem.
Old 02-21-2013, 12:43 PM   #5
HVAC Tech/Owner
Rewards Points: 604
Absolutely solved the immediate problem...however...A hunter thermostat? Might as well put an on/off switch on the wall.
Especially with a heatpump.
Technow is offline   Reply With Quote
The Following User Says Thank You to Technow For This Useful Post:
hvactech126 (02-21-2013)
Trane Thermostat replacement Maursce HVAC 14 11-09-2012 09:39 PM
New Trane Heat Pump Thermostat cory_booth HVAC 0 08-30-2012 08:44 AM
Trane Thermostat Replacement roadbiker255 HVAC 7 07-24-2012 01:29 PM
Wiring on Hunter Analog Thermostat woomama HVAC 16 03-22-2010 01:52 PM
Upgraded to new Hunter model 44860 thermostat and now no emergency heat hlmaint HVAC 0 01-08-2010 01:17 PM
