Forums | Home Repair | Home Improvement | Painting | Interior Decorating | Remodeling | Landscaping
Old 01-19-2014, 11:40 AM   #1
Share |
Trane TDY060R9V3W4 not turnin on at all
I have a Trane XV90 series furnace that does nothing when heat is called. I am able to manually turn the blower on which makes me think the board is good.
Also, I'm getting no error flashes on the red LED.
Any ideas?
Thanks.
sgip2000 is offline   Reply With Quote
Old 01-19-2014, 12:27 PM   #2
An old Tradesmen
Jumper R and W on the furnace control's terminal board. Then see if it runs.
The Following 2 Users Say Thank You to beenthere For This Useful Post:
ben's plumbing (01-19-2014), hvactech126 (01-19-2014)
Old 01-19-2014, 01:38 PM   #3
Tried that and nothing.
Old 01-19-2014, 02:15 PM   #4
AKA HVACTECHFW
did you push the door switch in?
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 01-19-2014, 03:43 PM   #5
Yes, I taped it "closed".
Old 01-19-2014, 03:49 PM   #6
AKA HVACTECHFW
If that is the case and the blower can be controlled by the thermostat then it is likely a control board failure.... you should call a professional to be sure though as they can check things in person......
Just checking you jumpered R to W1 not W2 correct?
IT IS WHAT IT IS
Old 01-19-2014, 05:01 PM   #7
Correct. R and W1 jumpered and nothing.
I was afraid it may be the board. That thing is expensive!
Old 01-19-2014, 05:07 PM   #8
AKA HVACTECHFW
It may be more than just the board... the correct replacement may be a KIT that includes, control board, ignitor, inducer, and wiring harness... If it is a KIT that includes all that then I HIGHLY recommend a professional for installation.
While a call for heat is present do you get any red flashes from the control board? If so count the flashes between the pauses.
IT IS WHAT IT IS
The Following User Says Thank You to hvactech126 For This Useful Post:
sgip2000 (01-19-2014)
Old 01-19-2014, 05:13 PM   #9
No flashes. Red LED comes on once after power is restored but does not flash.
Old 01-19-2014, 05:46 PM   #10
AKA HVACTECHFW
Looks like the replacement control board is a KIT15816 which includes a board and ignitor.... you should be able to do that yourself....
IT IS WHAT IT IS
Old 01-20-2014, 02:16 PM   #11
Well, just had a pro out and he confirmed the problem is the board. Any good sources for a new board?
Old 01-20-2014, 05:02 PM   #12
AKA HVACTECHFW
Check online............
IT IS WHAT IT IS
Old 01-20-2014, 07:30 PM   #13
I found one online for $430. Thanks.
Old 01-20-2014, 07:33 PM   #14
Thanks everyone for the help.
Here's what's wrong.
The Following User Says Thank You to sgip2000 For This Useful Post:
47_47 (01-21-2014)
Older Trane 90xl Furnace Perry401 HVAC 1 11-15-2013 12:00 AM
Trane Thermostat Replacement roadbiker255 HVAC 7 07-24-2012 01:29 PM
Trane XR90 - Condensate Drane Trap JDWorks HVAC 16 02-07-2012 07:59 PM
Ruud vs Trane peter_holmes HVAC 23 07-28-2010 02:32 PM
new install of Trane XL15i nind HVAC 32 01-30-2010 12:59 PM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
