Trane System Continious Air Flow Problem? - HVAC - DIY Chatroom Home Improvement Forum
Old 05-08-2012, 04:39 PM   #1
Rewards Points: 640
Trane system continious air flow problem?
Had a trane system installed in the other house now, it is supose to have 24x7 continious air flow, but it's not!
its a trane xc95m communicating system with a xl20i ac unit and a TCONT900 thermostat, so a complete communicating system with a cleaneffects air cleaner also in communicating mode.
the continious air flow is set to 40% when no calls are going..
it will run for a while, then it seems it randomly just goes off... the thermostat says Fan "on" but the blower is off.. i can turn the furnace off (power cycle at the switch) and go back on and its still off...
the programmable schedule on the thermostat has all 7 days and all 4 periods of the day set for the fan to be on
the thermostat says the fan is on, but its not
when a heat or cool call comes the blower starts up...
when in heat only mode it seems to work most of the time, when in cool only mode this seems to happen the most in auto (heat/cool switchover) mode it happens a good bit too...
any ideas?
the entire system is voltage + data line, so it's not the wires messed up, its only 2 to the AC, 3 to the thermostat, and 3 to the air cleaner
BlueBSH is offline   Reply With Quote
Old 05-08-2012, 06:09 PM   #2
Rewards Points: 150
You must likely need to program the tstat. The tcont900 is like the Honeywell IAQ and I am pretty sure it has a function for continous fan mode. You can also just turn it on to "Fan ON". Also you said that there is only 2 wires out to the xl20i? Is this a 2 stage unit? It should have maybe more like 4 wires in total. But I am not 100% percent sure. Maybe one of the pros here can comment on that. Check your manual your installer probably left with you for more info.
edit:
I found the manual online.
http://www.butcherdistributors.com/I...0installer.pdf
kilosos2 is offline   Reply With Quote
Old 05-08-2012, 06:45 PM   #3
An old Tradesmen
Rewards Points: 6,476
make sure the thermostat is fully on its base plate. other then that, i have no idea.
Old 05-08-2012, 07:00 PM   #4
DIY hobbyist
check the dip switches inside the air handler..
ggold is offline   Reply With Quote
Old 05-08-2012, 07:32 PM   #5
Rewards Points: 640
there are no dip switches on the xc95m, it's all on a LCD screen
Old 05-08-2012, 07:34 PM   #6
Rewards Points: 640
edit:
the continious on fan mode is set, its currently set to run at 40% of the max speed, and right now it is set to fan on, and the fan is off... but when a heat or cool call come in the fan comes on.. the xl20i is two stage, but it only has 2 wires, its a communicating model, it only needs a common and a data wire (well it also has the 30 amp 240v line too, but i'm not counting that)
Old 05-08-2012, 07:38 PM   #7
Rewards Points: 640
ok this is getting more confusing, I just turned the system from Cool to Off and the blower came on
Old 05-08-2012, 07:58 PM   #8
DIY hobbyist
is it programed to match outdoor unit ?
Old 05-08-2012, 08:15 PM   #9
Rewards Points: 640
not sure what you mean, the entire system is auto learning via the communicating interface
Old 05-08-2012, 08:21 PM   #10
DIY hobbyist
you should be able to scroll through the menu on the screen, it should ask for condensor unit model
Old 05-08-2012, 09:12 PM   #11
Rewards Points: 150
Maybe thats how the continuous are flow works? Try contacting Trane. For sure there is a setting to do this. The other only thing you can do is set the Fan "ON" mode.
Old 05-08-2012, 09:49 PM   #12
Rewards Points: 616
contacting Trane......... that made me laugh....
carmon is offline   Reply With Quote
Old 05-08-2012, 11:17 PM   #13
AKA HVACTECHFW
Rewards Points: 1,208
Are you using a schedule? If so, make sure all periods in your schedule on every day are set to fan ON.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 05-09-2012, 11:03 PM   #14
Rewards Points: 640
figured it out after reading the whole installer manual....
read something about humidity control with the blower, turned it off and the blower never turns off now guess this only is supose to happen when cool has been on in the past x amount of time, its to stop water on the coil from being evaporated back into the air... why it turns it off when the blower says its on, guess thats a stupid honeywell design, but at least now it makes some sense
Old 05-10-2012, 08:12 AM   #15
Rewards Points: 640
yep all where on, and the main system fan setting was also on nothing was on circ or auto
Slow Hot Water Flow problem NateSmith Plumbing 8 04-25-2011 07:52 PM
advice please! - new TRANE HVAC system ACtawk HVAC 2 10-07-2010 05:25 PM
Centre Air conditional system problem Ballastar HVAC 2 06-08-2010 09:44 PM
Flow not Pressure problem??? DonM Plumbing 5 11-29-2007 06:53 PM
Trane 80xl, 3 flashes error light - draft pressure problem, help? Xsta HVAC 1 10-14-2007 09:20 PM
