Trane Quote - HVAC - DIY Chatroom Home Improvement Forum
Old 05-10-2014, 01:39 AM   #1
Trane quote
Hey all,
I got a quote for a Trane split system and it seems high and I just wanted to get an idea if my gut is right.
I have a 4000sqft two level home with two zones (upstairs and down). After all the calcs (a lot of time was spent there), it looks like we need just shy of a 5 ton system. The quote was just for equipment and installation. There's no extra ductwork or anything like that.
Non-modulating:
Furnace: XV95 - 5500
A/C: XL18i - 9000
Modulating:
Furnace: XC95m - 6600
A/c: XV20i - 11000
If this is off the mark, what's a good ballpark for this system? I'm in the Pacific Northwest if it matters.
Thanks,
SC
SirCochese is offline   Reply With Quote
Old 05-10-2014, 07:08 AM   #2
An old Tradesmen
Rewards Points: 6,074
Is the A/C your replacing also 5 tons?
Old 05-10-2014, 03:52 PM   #3
Yep, a Lennox builder special freon single stage 5 ton. The kicker is that single stage. With a zoned system the single stage is way overkill when only one floor needs cooling.
Old 05-11-2014, 05:43 AM   #4
An old Tradesmen
Your quotes are on top of the line equipment, so the prices will be higher. I believe they must also be installing a Trane zoning panel and stats to use the mod furnace and modulating xv20i A/C.
Old 05-12-2014, 02:47 AM   #5
Sure, I get that it's a big step up, but I was just wondering if anyone else out there had some comparative quotes to know if this one is out of line.
Thanks for your reply!
Old 05-12-2014, 05:02 AM   #6
An old Tradesmen
Being a DIY site. Most members have more experience in repairing their heat and cooling systems then getting quotes on new ones.
Prices vary from 1 area to the next. Best way to compare, is to get more prices from either another Trane dealer, or a dealer of another brand using that brand's same line equipment.
The Following User Says Thank You to beenthere For This Useful Post:
hvactech126 (05-12-2014)
Old 05-12-2014, 05:50 AM   #7
Rewards Points: 166
This isn't really the same, but I just got four quotes to install a heat pump and electric air handler with heat strips in my 3600 sq/ft house with existing duct work. (Replacing an oil furnace)
All four quotes were between 12,000 and 14,000 for the high-end equipment.
I thought it was pretty high at first but the last one came with an itemized cost breakdown which made it the quotes look a bit more reasonable. The only item I still think is high is the labor cost, but I assume that's where they built in their profit.
dftc is offline   Reply With Quote
Older Trane 90xl Furnace Perry401 HVAC 1 11-15-2013 01:00 AM
Trane Thermostat Replacement roadbiker255 HVAC 7 07-24-2012 02:29 PM
Trane XR90 - Condensate Drane Trap JDWorks HVAC 16 02-07-2012 08:59 PM
Ruud vs Trane peter_holmes HVAC 23 07-28-2010 03:32 PM
new install of Trane XL15i nind HVAC 32 01-30-2010 01:59 PM
