Trane Pressure Switch - HVAC - DIY Chatroom Home Improvement Forum
Old 10-21-2011, 05:33 PM   #1
trane pressure switch
I have a trane YCC gas pack, It is blinking three times on the board. When I turn on the unit at the thermostat the inducer fan comes on and the switch opens and I am getting 27 volts at the switch. I runs for a minute or so and cycles and repeats but never fires up. Got any ideas?
captmills is offline   Reply With Quote
Old 10-21-2011, 05:43 PM   #2
biggles's Avatar
the switch should close with no reading of 24Vs the air pressure closes that switch "can't read voltage in series" go to ground off each screw on the pressue switch if you read 24Vs from each the switch is closed.......jump the switch if the ID is runnig see if you get the cycle of heat consant switch might be bouncing check the tube from the motor discharge for water moisture
Old 10-21-2011, 07:34 PM   #3
Houston204's Avatar
Rewards Points: 556
The squirrel cage on package units tends to rust and fall apart with age.
Do you feel air blowing out of the vent? (highlighted red in the picture)
Houston204 is offline   Reply With Quote
Old 10-22-2011, 07:07 AM   #4
thanks for the good words, I'll check the switch again this morning. The fan is good, I replaced it 2 years ago and is blowing fine.
Old 10-22-2011, 12:00 PM   #5
went to check the voltage this morning and was surprised that the unit was running hate things that come and go, hard to diagnois. Thanks guy's
Pressure Switch Question loftezy HVAC 11 04-12-2011 05:57 PM
Pressure switch or other? rickr01 HVAC 1 11-08-2010 06:28 PM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 07:14 PM
Pressure switch issue? or something else... rp4985 Plumbing 8 07-11-2009 03:31 PM
New Pressure Switch -- low water pressure chach Plumbing 4 01-18-2009 10:50 PM
