Trane Only Vent Motor Coming On. - HVAC - DIY Chatroom Home Improvement Forum
Old 09-16-2010, 08:33 AM   #1
Trane only vent motor coming on.
When I turn on my heat the vent motor comes on for a few minutes and then quits. After couple of minutes it tries again with the same result. It keeps doing this and the burners never ignite. Any ideas?
lyssa98 is offline   Reply With Quote
Old 09-16-2010, 08:45 AM   #2
fabrk8r
fabrk8r's Avatar
It could be a number of things. Could be as simple as a gas petcock turned off. It could be a bad ignitor, limit switch, defective gas valve or it could be a blockage in the vent pipe.
How old is the unit?
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 09-16-2010, 09:03 AM   #3
It was installed in 2003. Gas is on. Unsure if ignitor is glowing or not. I will do more research when I get home tonight.
Old 09-16-2010, 12:23 PM   #4
HVAC / Plumbing
See if you have a light on the circuit board that's blinking., Count the blinks . look on the blower panel for the code.. You can also check to see if ignitor is glowing or not
kenmac is offline   Reply With Quote
The Following User Says Thank You to kenmac For This Useful Post:
fabrk8r (09-16-2010)
Old 09-16-2010, 12:55 PM   #5
Thanks for the advice. I'll do that when I get home!
Old 09-16-2010, 04:41 PM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 2,318
Post the make, model and serial #.
Old 09-16-2010, 05:04 PM   #7
Got home and turned the furnace on and it worked! don't know why. I have a Trane XR90. The red light on the board was blinking. No morse code just steady blinking. I still think this has potential to happen in January. I live in MN and that won't work. Should the red light be just "on"?
Old 09-16-2010, 05:22 PM   #8
An old Tradesmen
Rewards Points: 7,414
Nope. Its suppose to blink.
Old 09-16-2010, 05:40 PM   #9
Any reason why it didn't want to fire last night but now does?
Old 09-16-2010, 05:51 PM   #10
HVAC / Plumbing
If it's been off all summer . It could have just misfired on the 1st try.. May not happen again.. If there is a problem with it . It will happen again.. Might want to try it several times to be sure it will work when you need it
Old 09-17-2010, 08:44 AM   #11
Could it be that the ignitor was dusty and it took a while to burn off? Should I remove it and clean it anyway?
Old 09-17-2010, 09:00 AM   #12
fabrk8r
fabrk8r's Avatar
lyssa98, glad it's working again.
One question...did you happen to have any work done that involved disconnecting any of your gas lines since the last heating season?
Some times when a gas line is disconnected air gets trapped in a branch line and the gas valve on the connected appliance has to purge the air before gas will flow.
Old 09-17-2010, 10:25 AM   #13
I installed a gas water heater next to it in the fall of 2009 and had no issues with the furnace that winter. Nothing since then.
Old 09-17-2010, 03:01 PM   #14
HVAC / Plumbing
No. And don't remove the ignitor & clean it
Old 09-17-2010, 05:44 PM   #15
An old Tradesmen
Probably some sort of dust/dirt in the pressure switch hose, or a port on the switch or furnace.
Replacing Trane XL90 Vent Inducer NoSmoke HVAC 5 04-02-2010 04:14 PM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 05:47 PM
Trane XE 80 vent motor replacement DJfixer HVAC 3 12-26-2008 02:15 PM
Bubbling in toilet rballard Plumbing 11 08-30-2008 07:15 PM
