Trane - Not Powering Thermostat - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 10-22-2011, 07:45 PM   #31
Don't feel bad. I know a guy whom is an awesome hvac technician. His personal truck broke down one day. After a fuel pump relay, ignition module, crank sensor and new cap rotor and wires, I went over and found out he was out of gas....
Master of Cold is offline   Reply With Quote
Old 10-22-2011, 07:46 PM   #32
Purple in place of red
Old 10-22-2011, 07:56 PM   #33
Rewards Points: 472
Originally Posted by Splitz300 View Post
Do these typically go bad like that "all of a sudden" in the manner originally described? Unit is only just over 5 years old.
I could understand the contact relay going bad before a transformer, but I'm not an expect in these (obviously). I can force the system on by depressing the contact in the middle of the relay block.
Does the control board require 24VAC to illuminate the LED?
I bet that transformer has 110volt AC input and 24volt ac out thro diodes to make up DC voltage ?? i don't belive diode's work on AC voltage. I would look to replace the PC board it will be a complete board. May be exchanged Don't know the warrenty contact the mfd. and see and also ask about a PC board. Most likey the doide's are bad not the trans. But those are cheep transf. Check voltage on one side 110volt ac not on the other side 24volt ac now their should be some little diode's right around their also . With a ohm meter check frount to back and see if the reading is different? If the same they are shorted. Now they should be unsoldered one end and check that way. Best to just get a new board. Been in repair for 50 yrs. Now retired
del schisler is offline   Reply With Quote
Old 10-22-2011, 07:56 PM   #34
I'm Your Huckleberry
Rewards Points: 2,270
is this really true? what airline does he work for?..
Doc Holliday is offline   Reply With Quote
Old 10-22-2011, 07:58 PM   #35
Do you ever wonder about reading comprehension?
Old 10-22-2011, 08:01 PM   #36
I can't read so there's nothing to comprehend.
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 09:43 AM
Need help connecting Trane TZEMT400 Thermostat; no 'C' wire / 24VAC dinki HVAC 1 04-04-2011 07:28 PM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 05:32 PM
Trane Z Wave Thermostat Installation TommyTelephone HVAC 1 09-13-2009 04:51 AM
Help with Trane HVAC Thermostat taylorjo32327 HVAC 0 07-22-2009 02:31 PM
