Trane - Not Powering Thermostat - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-22-2011, 05:19 PM   #16
biggles's Avatar
the board receives 24V from the tr and then with the stat connected it controls the board and the out side condenser....the relays on the board control the fan 115Vs to run the fan either from the stat in cooling or FAN/ON off the subbase,or during the heating which could be a time delay on a call for heat the 2 black relays on that board are rated as you see..if anything is powered and you get a surge from the pole the weakest items will take a hit if you remove the old TR ring out both sides with the ohm meter setting see which doesn't have continuity thats what took the hit
Old 10-22-2011, 05:24 PM   #17
Originally Posted by Master of Cold View Post
Are you looking for the transformer in the outside unit?
The transformer is in the inside unit. There will also be a fuse in the 18 gauge red wire.
The handling unit is in the attic, no fuse, just a 60A breaker which I reset a few times before this all started. There's a similar relay block as in the outside unit.
I took off the relay block from the heat pump outside, not necessariliy a short, but showing 18Ω.
Splitz300 is offline   Reply With Quote
Old 10-22-2011, 05:25 PM   #18
Originally Posted by Doc Holliday View Post
Yup, dogs love chewing on those wires as well.
Last month I went on a call back, our company had installed a new evaporator coil and one month later the system wasn't working. The tenant, an elderly woman in her seventies, had a stroke while there. Mind you we were in a record heat wave here in Texas, over 30 consecutive days of over 100 degree ambient (outside) temperature. Inside a home it can be devastatingly hot in those conditions. People do die down here in the Summer, more than I'd like to admit.
Where in Texas are ya?!?!?!?!?!
Old 10-22-2011, 05:30 PM   #19
I'm Your Huckleberry
Rewards Points: 2,270
Deep in the Heart of it.
Houston.
Doc Holliday is offline   Reply With Quote
Old 10-22-2011, 05:41 PM   #20
Houston.
Ah, crap.
Oh well, worth a shot.
Just to confirm, the 24VAC Transformer is behind this contact relay:
Old 10-22-2011, 05:46 PM   #21
"Houston, we have a problem"
Master of Cold is offline   Reply With Quote
Old 10-22-2011, 05:48 PM   #22
That part pictured is the windings of the electromagnet, for the contactor relay. The transformer is in the air handler.
Old 10-22-2011, 06:02 PM   #23
Here's a pic of the air handler stuff.
There's a 60A breaker that has huge red wires going from the blower motor then to the outside.
I read 0VAC at all points.
Could it be something as simple as this breaker???
The contactor below that, when you hit the contact in the middle, turns on the heat...ask me how I know...LOL
Old 10-22-2011, 06:17 PM   #24
The only way to get 24 volts from 120 or 240 is through a transformer. Just because you don't see it doesn't mean it's not there. Look for the wiring diagram and find the tranny, it is there. Look by the blower.
Old 10-22-2011, 06:18 PM   #25
5A Fuse.
F M L
8 hours to troubleshoot to a fricking 5A FUSE? Are you kidding me? Glad I'm in aircraft repair and not HVAC troubleshooting.
Well, at least I didn't have to spend $89 for said fuse.
I assume any automotive fuse will work?
Old 10-22-2011, 06:27 PM   #26
Any 5 amp auto fuse, yes. One and the same.
Old 10-22-2011, 06:35 PM   #27
In my haste of taking the fan off the heat pump, I don't remember what color wires go where.
Old 10-22-2011, 06:37 PM   #28
You're screwed now!
take some pictures, good ones. trace back wires and take pictures there as well.
Old 10-22-2011, 06:41 PM   #29
Black to defrost board, red to cap "c" terminal
Brown to cap "f" terminal.
Old 10-22-2011, 06:44 PM   #30
I have puple, black, and brown. LOL
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 08:43 AM
Need help connecting Trane TZEMT400 Thermostat; no 'C' wire / 24VAC dinki HVAC 1 04-04-2011 06:28 PM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 04:32 PM
Trane Z Wave Thermostat Installation TommyTelephone HVAC 1 09-13-2009 03:51 AM
Help with Trane HVAC Thermostat taylorjo32327 HVAC 0 07-22-2009 01:31 PM
