Trane Newbie Needs Help - HVAC - Page 4 - DIY Chatroom Home Improvement Forum
Old 06-16-2012, 06:56 PM   #46
ADRIEN1's Avatar
Originally Posted by hvactech126 View Post
check continuity of the fuse....
Do I just put both ends red on one side and black on the other of my volt meter?
ADRIEN1 is offline   Reply With Quote
Old 06-16-2012, 06:59 PM   #47
AKA HVACTECHFW
Rewards Points: 1,208
you must have an ohm meter or a multimeter set to ohms, but yes that is how you would do it.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 06-16-2012, 07:00 PM   #48
JJboy's Avatar
Originally Posted by ADRIEN1 View Post
I just tested the red wires at the thermostat and no 24 volts the lights to the board still don't come on. I do have 26 volts on the otherside of the transformer. I also chaged out the condensor board and still nothing. I just went through cut all the wires to the ltv board and redid them to the specs in the diagram and still not working. I am about to cry> Should I still try to twist the stat wires together?
Check continuity of wires between control board and thermostat
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 06-16-2012, 07:08 PM   #49
AKA HVACTECHFW
that wont do any good as there is no voltage @ the lvtb
IT IS WHAT IT IS
Old 06-16-2012, 07:15 PM   #50
JJboy's Avatar
Ok, lets put detail ..... then test the wires between the transformer and control board / thermostat
Old 06-16-2012, 07:18 PM   #51
ADRIEN1's Avatar
oK I am about to bow out. I need really detailed info about how to test the voltage between the transformer and board where do I put it. Here are a few of the pics I promised this isn't looking to good.
Old 06-16-2012, 07:21 PM   #52
I'm Your Huckleberry
Rewards Points: 2,270
Hummina hummina hummina hummina!!!
Thanks.
Doc Holliday is offline   Reply With Quote
The Following 2 Users Say Thank You to Doc Holliday For This Useful Post:
ADRIEN1 (06-16-2012)
Old 06-16-2012, 07:30 PM   #53
JJboy's Avatar
Ok,,,,give me your address I'll get the airplane right now with my camera.....and tools of course....
The Following User Says Thank You to JJboy For This Useful Post:
hvactech126 (06-16-2012)
Old 06-16-2012, 07:35 PM   #54
AKA HVACTECHFW
roflmao!!
IT IS WHAT IT IS
Old 06-16-2012, 07:37 PM   #55
AKA HVACTECHFW
Adrien, thanks for the pics, unfortunately there is not much more we can do over the internet for you. It may be time to call in a pro...
IT IS WHAT IT IS
Old 06-16-2012, 07:53 PM   #56
ADRIEN1's Avatar
I think you are right I just had a tech look at it and he said he can't figure it out either. He wasn't trane cerified though. Look like I have to get a trane tech and pull out the big bucks. Thanks for all your help guys.
Tags
board not powering up , trane
Trane XE78 Furnace coupled with Trane 1000 AC JND HVAC 3 05-26-2012 03:53 PM
Trane XR90 - Condensate Drane Trap JDWorks HVAC 16 02-07-2012 07:59 PM
Newbie has issues with Trane XE80 hayescary HVAC 26 12-11-2011 09:46 AM
Ruud vs Trane peter_holmes HVAC 23 07-28-2010 02:32 PM
new install of Trane XL15i nind HVAC 32 01-30-2010 12:59 PM
