Trane Newbie Needs Help - HVAC - DIY Chatroom Home Improvement Forum
Old 06-16-2012, 09:01 AM   #1
ADRIEN1's Avatar
Trane newbie needs help
Me and my Dad removed a 3 ton air handler and condensor Trane 2 stage inside and out 2007 from his home and put it in my house. We hooked up everything the same but the board lights in the air handler won't turn on and the unit is acting dead???? I changed the board inside the transformer is getting 230v and putting out 26 volts all connections look tight but still won't turn on? It was blowing cold at his home. Can this be due to the TCONT 802 digital t stat anyone have the wiring diagram for this?? I have never seen anything like this before please help desperate woman here in New Orleans.
ADRIEN1 is offline   Reply With Quote
Old 06-16-2012, 09:09 AM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Pictures, and the two women in your avatar and I'll tell you how to fix it.
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
hvactech126 (06-16-2012)
Old 06-16-2012, 09:14 AM   #3
ADRIEN1's Avatar
Pictures of the unit?
Old 06-16-2012, 09:14 AM   #4
all wiring
Thanks.
Old 06-16-2012, 09:17 AM   #5
ADRIEN1's Avatar
Ok I will take them an post them shortly have to go into the attic.
Old 06-16-2012, 09:57 AM   #6
AKA HVACTECHFW
Rewards Points: 1,208
model numbers help also!
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 06-16-2012, 10:15 AM   #7
ADRIEN1's Avatar
AIR HANDLER MODEL#2TEE3F37A1000AA
CONDENSOR MODEL# 2TT29036B1000BA
HAVE INSTALLED A NEW BOARD IN AIR HANDLER CHECKED BREAKER AND GETTIG 230 VOLTS COMING INTO UNIT
CHANGED TRANSFORMER IT HAS 230 VOLTS GOINT IN 23 VOTS COMING OUT
CHANGED CONTACT ALSO INSIDE AIR HANDLER.
ON CONDENSOR PUSED IN CONTACT AND BOTH COMPRESSORS KICK ON STAGE 1 AND 2 NOT AT SAME TIME BUT WHEN PRESSING EACH CONTACT.
ONLY THING I AM NOT SURE ABOUT IS T STAT I HAVE 3 OF THEM AND THE FACES COME OFF I HAVE PLUGED ALL IN THOUGH AND THE UNIT BOARD LIGHTS STILL DON'T COME ON.
I ALSO VERIFED THE T STAT TCONT 802 is set to the rigt cycle electric heat and 2 stage heat and 2 stage cool.
PLEASE ANYONE??
Old 06-16-2012, 10:31 AM   #8
Instead of shouting you might want to get to those pics. All wiring of every wingle component, board, high voltage, transformer, stat, condenser.
Thanks.
Old 06-16-2012, 10:32 AM   #9
AKA HVACTECHFW
What is voltage between R and C on control board. Is the fuse blown?
IT IS WHAT IT IS
Old 06-16-2012, 10:37 AM   #10
ADRIEN1's Avatar
More pics to come
Trane newbie needs help-.jpg   Trane newbie needs help-b.jpg   Trane newbie needs help-c.jpg
Old 06-16-2012, 10:42 AM   #11
AKA HVACTECHFW
That is a lot of rust on the LVTB!
IT IS WHAT IT IS
Old 06-16-2012, 10:46 AM   #12
ADRIEN1's Avatar
Sorry for the caps was 175 in that attic,by the way my name is Adrien I am the woman on the left n the pic. Here are some more pics. I also changed the fuse.
Trane newbie needs help-h.jpg   Trane newbie needs help-i.jpg   Trane newbie needs help-k.jpg
Old 06-16-2012, 10:48 AM   #13
ADRIEN1's Avatar
I am on the right the computer flipped me lol.
The Following User Says Thank You to ADRIEN1 For This Useful Post:
Old 06-16-2012, 10:49 AM   #14
ADRIEN1's Avatar
I thought the same thing but like I said it was working just 4 days ago when I removed it.
Old 06-16-2012, 10:55 AM   #15
I'm sorry but I just can't concentrate on your air handler, I'm too smitten with you.
Thanks.
Tags
board not powering up , trane
Trane XE78 Furnace coupled with Trane 1000 AC JND HVAC 3 05-26-2012 04:53 PM
Trane XR90 - Condensate Drane Trap JDWorks HVAC 16 02-07-2012 08:59 PM
Newbie has issues with Trane XE80 hayescary HVAC 26 12-11-2011 10:46 AM
Ruud vs Trane peter_holmes HVAC 23 07-28-2010 03:32 PM
new install of Trane XL15i nind HVAC 32 01-30-2010 01:59 PM
