Trane newbie needs help
Me and my Dad removed a 3 ton air handler and condensor Trane 2 stage inside and out 2007 from his home and put it in my house. We hooked up everything the same but the board lights in the air handler won't turn on and the unit is acting dead???? I changed the board inside the transformer is getting 230v and putting out 26 volts all connections look tight but still won't turn on? It was blowing cold at his home. Can this be due to the TCONT 802 digital t stat anyone have the wiring diagram for this?? I have never seen anything like this before please help desperate woman here in New Orleans.
Pictures, and the two women in your avatar and I'll tell you how to fix it. :)
Pictures of the unit?
all wiring
Ok I will take them an post them shortly have to go into the attic.
model numbers help also!
AIR HANDLER MODEL#2TEE3F37A1000AA
CONDENSOR MODEL# 2TT29036B1000BA HAVE INSTALLED A NEW BOARD IN AIR HANDLER CHECKED BREAKER AND GETTIG 230 VOLTS COMING INTO UNIT CHANGED TRANSFORMER IT HAS 230 VOLTS GOINT IN 23 VOTS COMING OUT CHANGED CONTACT ALSO INSIDE AIR HANDLER. ON CONDENSOR PUSED IN CONTACT AND BOTH COMPRESSORS KICK ON STAGE 1 AND 2 NOT AT SAME TIME BUT WHEN PRESSING EACH CONTACT. ONLY THING I AM NOT SURE ABOUT IS T STAT I HAVE 3 OF THEM AND THE FACES COME OFF I HAVE PLUGED ALL IN THOUGH AND THE UNIT BOARD LIGHTS STILL DON'T COME ON. I ALSO VERIFED THE T STAT TCONT 802 is set to the rigt cycle electric heat and 2 stage heat and 2 stage cool. PLEASE ANYONE?? |
Instead of shouting you might want to get to those pics. All wiring of every wingle component, board, high voltage, transformer, stat, condenser.
What is voltage between R and C on control board. Is the fuse blown?
3 Attachment(s)
More pics to come
That is a lot of rust on the LVTB!
3 Attachment(s)
Sorry for the caps was 175 in that attic,by the way my name is Adrien I am the woman on the left n the pic. Here are some more pics. I also changed the fuse.
1 Attachment(s)
I am on the right the computer flipped me lol.
I'm sorry but I just can't concentrate on your air handler, I'm too smitten with you. :thumbup: |
| All times are GMT -4. The time now is 10:39 AM. |
