Trane To Nest Thermostat. - HVAC - DIY Chatroom Home Improvement Forum
Old 01-29-2014, 01:43 PM   #1
Rewards Points: 12
Trane to Nest thermostat.
Hey guys.
I have 3 1/2 ton Trane heat pump. All electric with aux heat.
Im replacing the thermostat with a Nest gen1. ( i got a smoking deal on it and wife likes it so that why i got it). I have talked to nest customer service through email with pictures to verify if it was compatible and there suggested wiring. Anyways i havent attempted to do anything yet. at first they said it appears to be compatible but needed more pics to verify the x2 wire. Now They think both O and B both control reversing valve. And that B wasnt the common. thus making it incompatible. Can anyone verify this.
Heres some pics...
Trane to Nest thermostat.-trane-thermo.jpg   Trane to Nest thermostat.-3.jpg   Trane to Nest thermostat.-1.jpg   Trane to Nest thermostat.-2.jpg   Trane to Nest thermostat.-nest-gen1.jpg
tool man Taylor is offline   Reply With Quote
Old 01-29-2014, 03:07 PM   #2
sktn77a's Avatar
Rewards Points: 360
O controls the reversing valve on Trane and most other makes. B controls it on Rheem/Ruud. The O/B setting is probably selected in the thermostat programming screen on the NEST. It's odd to have 2 B connections and 2 O connections. You may need a Pro to advise you on this one.
EDIT: The B wire in the Trane thermostat pic may not be connected through to the air handler/heatpump.
sktn77a is offline   Reply With Quote
Old 01-29-2014, 04:03 PM   #3
Rewards Points: 12
thanks.
I originally planned to do this:
WIRE - NEST
blue - C
red - RH
white - W1
green - G
orange - OB
yellow - Y1
and leave off X2 as i thought that was emergency heat and Nest1 doesnt support that.
so from the pics can we confirm blue wire is the common?
X2 emergency heat?
Old 01-29-2014, 07:05 PM   #4
An old Tradesmen
Rewards Points: 6,116
The blue wire is the common, and X2 the emergency heat.
Keep your old stat. You may need it.
The Following User Says Thank You to beenthere For This Useful Post:
tool man Taylor (01-29-2014)
Old 01-29-2014, 07:58 PM   #5
Rewards Points: 12
Thanks.
Not sure what made them think O and B wire both controlled the reversing valve.
Old 01-29-2014, 09:15 PM   #6
An old Tradesmen
Originally Posted by tool man Taylor View Post
Thanks.
They really don't know much about HVAC systems.
Old 01-29-2014, 11:28 PM   #7
HVAC Tech/Owner
Rewards Points: 604
And they don't know much about making a reliable thermostat either.
Technow is offline   Reply With Quote
The Following User Says Thank You to Technow For This Useful Post:
beenthere (01-30-2014)
Old 01-30-2014, 09:39 AM   #8
Rewards Points: 12
Btw i ask Nest Why they thought B was reversing valve as i thought it was the common....and they replied that it was labeled B on the control board instead of C.
Old 01-30-2014, 04:42 PM   #9
An old Tradesmen
B on Rheem/Ruud heat pumps is the reversing valve. They reverse on a heat call instead of a cooling call.
Trane THUMD500 and Nest Thermostat bluefoxicy HVAC 4 01-09-2014 11:44 PM
How to Install NEST thermostat with Trane Axiom Water-Source Heat Pump momo9864 HVAC 1 05-22-2013 10:19 AM
Trane Thermostat replacement Maursce HVAC 14 11-09-2012 10:39 PM
New Trane Heat Pump Thermostat cory_booth HVAC 0 08-30-2012 09:44 AM
Trane Thermostat Replacement roadbiker255 HVAC 7 07-24-2012 02:29 PM
