Old 01-21-2009, 08:44 PM   #1
Cool
trane mod# twe060c15fdo no heat, help
this is str/cool unit, i have no heat, t-stat calls for heat but i get no heat
i checked the heat strips with my meter they are good, i'm wondering is there a heat relay? i don't seem to see one, but i do see a relay with a ciruit board attacted to it,,don't know if this is a heat relay as well as a blower time delay? not sure if it does both? there is a contactor inside the a/h don't know what that does? please help me with this problem,, i do know how to use a meter,if thats helps..thank you,,,its very cold here, help,,
itsme711 is offline   Reply With Quote
Old 01-21-2009, 10:03 PM   #2
JohnH1's Avatar
Start with the basics. 1st if you turn the fan switch at the t-stat to on will the blower run?
JohnH1 is offline   Reply With Quote
Trane Heat Pump acting up..frozen (XR13) VEIK HVAC 1 10-20-2008 04:00 PM
Are Trane heat pumps and Am Std exactly the same? jgtaylorjr HVAC 1 06-01-2008 10:35 PM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 10:10 PM
