Trane Ignitor Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 01-10-2010, 10:23 AM   #1
Trane ignitor problem
I just replaced the ignitor and sensor on my xv80.It was flashing 9 times which is ignition problems on the code chart.Worked great for 2 days and now the same thing is happening.Blowing cold air and the ignitor is not glowing.Any ideas on this problem.Thanks
antlers is offline   Reply With Quote
Old 01-10-2010, 10:46 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,818
Is it getting the proper voltage to the igniter during the startup cycle. Not sure what it is on the newer Tranes. Check it anyway and post it here. May be stamped on the igniter plug.
Old 01-10-2010, 11:09 AM   #3
I am getting 120 volts.I can not see anything on the ignitor as far as voltage requirements.Thanks
Old 01-10-2010, 11:32 AM   #4
If you have 120 volts to the ignitor and it's not red hot then it has failed. All I carry on the truck any more is the white rodgers nitride upgrades.
Old 01-10-2010, 11:44 AM   #5
Hvac Pro
yuri's Avatar
Never touch the igniter itself as it is very fragile and any finger oil on it can ruin it. Only touch the porcelain.
Old 01-10-2010, 11:44 AM   #6
I just replaced this 2 days ago.Why is it failing already again.Thanks
Old 01-10-2010, 11:47 AM   #7
Hvac Pro
yuri's Avatar
Rough handling before you got it, defective igniter (very rare). Check it with an ohm meter, should be around 50 ohms. Where did you buy it from.
Old 01-10-2010, 11:49 AM   #8
I did not touch the ignitor.I was told that i should only have 80 volts going to the the ignitor.Can anyone confirm this.I thought they all should receive 120 volts.Thanks
Old 01-10-2010, 11:51 AM   #9
I bought it from a trane dealer.Thanks for the help yuri.I also bought the motherboard just in case but i am hoping not to have to install it and save the money.
Old 01-10-2010, 11:58 AM   #10
Hvac Pro
yuri's Avatar
Lennox uses a reduced voltage igniter not sure about Trane. Post the complete model and serial # and someone will help you later today, be patient.
Old 01-10-2010, 12:04 PM   #11
Model # TUD080R9V3K0 serial Z472PDL1G Thanks again yuri
Old 01-10-2010, 12:11 PM   #12
Dirty burners causing a delayed ignition will crack them almost every time. This is the one I use. http://www.johnstonesupply.com/corp/...t_Code=L41-806 Most supply houses carry the same thing,johnstone is just the closest one to our shop.
Old 01-10-2010, 06:13 PM   #13
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
if its blowing cold air when furnace isnt running id check for open limit switch
plummen is offline   Reply With Quote
Old 01-11-2010, 08:18 AM   #14
The burners are clean.Anyone know the output for the the ignitor on this model.I dont want to put another ignitor if the board is going to blow it again.Thanks
Ruud vs Trane peter_holmes HVAC 23 07-28-2010 02:32 PM
Need some friendly advice-- Coleman/York v. Trane biggerdaddynj HVAC 3 05-09-2010 10:46 AM
new install of Trane XL15i nind HVAC 32 01-30-2010 12:59 PM
Humid - Switched Trane xl1200 AC for a Payne HP - now very Humid dagrappler HVAC 1 06-11-2007 12:16 PM
