Trane HVAC Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 08-28-2011, 04:37 PM   #1
I am having trouble setting my AC to stay at 69 degrees. It keeps changing back to 75 degrees! I think it is programmed to change??
AC unit is Model # XV90
Also:
32003794-007
annmarie68 is offline   Reply With Quote
Old 08-28-2011, 04:45 PM   #2
30 year tech
hvac122's Avatar
There should be a hold button on it. Set the temp and hit hold and it should stay there. If you give us more info on the stat we may be able to help with the programing.
hvac122 is offline   Reply With Quote
Old 08-28-2011, 06:06 PM   #3
An old Tradesmen
Rewards Points: 7,818
Post brand and model number of the thermostat. The furnace and A/c model don't tell us anything about your thermostat.
Old 08-28-2011, 06:10 PM   #4
Thanks. It is the Trane theromstat with only digital screen, no other buttons.
We have tried this several times. We just did it again. and set the number of days to 7.
It is like it keeps resetting the setting to 73 and says the temp is 77 degrees.
Old 08-28-2011, 06:34 PM   #5
An old Tradesmen
Trane has several touch screen thermostats, tcon800, tcon802, tcon803.
Either go into schedule, and sett all events to the same temp, or go into installer setup, and tell it to be non programmable.
Old 08-28-2011, 07:38 PM   #6
Brand is: Trane
When I open it up, on the back I see:
4-HIPS
TCONT802AS32DAA
Old 08-28-2011, 07:45 PM   #7
OK, thanks. I have it on permanent hold (apparently we have set it to this before, but it keeps getting bumped off).
I can't seem to find installer set up.
Old 08-28-2011, 07:48 PM   #8
And it keeps saying hold temp for 1 day. I go to change the days to 30 days and then the temp setting goes back up to 73!! arggh.
Need help connecting Trane TZEMT400 Thermostat; no 'C' wire / 24VAC dinki HVAC 1 04-04-2011 06:28 PM
Thermostat issues rathipon HVAC 4 01-29-2011 11:46 AM
Adding second thermostat to HVAC unit hoanphu HVAC 3 12-07-2010 05:24 AM
Wiring Thermostat for HVAC UncaYimmy HVAC 8 05-07-2010 04:51 AM
Help with Trane HVAC Thermostat taylorjo32327 HVAC 0 07-22-2009 01:31 PM
