TRANE HVAC Breaker Turning Off - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-14-2012, 11:26 AM   #16
biggles's Avatar
the resistance heat should be on top of the airhandler or in the supply duct run out just off the air handler..or within it....if your tripping a breaker from that supply fan motor the heat has to be on the motor casing...115V wire bouncing out after 3 hours is kind of a fluke....and tripping a breaker....note also if the breaker trips do not reset with the heat fan calling all off then restart....if it was a dead short when switching it on the breaker would trip ...heat is tripping the breaker....
Breaker box wiring question(s) janralix Electrical 6 08-29-2010 10:13 PM
Trane hvac warranty question jlewi110 HVAC 1 10-21-2009 09:11 AM
small voltage on circuit with breaker off jasonmechler Electrical 3 08-24-2009 08:52 AM
Fan motor noise on a Trane HVAC LPVJ38 HVAC 3 08-05-2009 09:52 PM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
