Trane Heat Pump Tstat And Reversing Valve - HVAC - DIY Chatroom Home Improvement Forum
Old 02-03-2013, 09:52 AM   #1
Trane heat pump Tstat and reversing valve
I have a Trane TCON900 programmable Tstat....
Downloaded the manual to try to find where the outdoor air cutout temp could be adjusted. I have heat pumps with gas back-up. Manual mentions this feature but doesn't tell you the code number or how to adjust it.
Also, 1.5 ton unit compressor just started "rattling" for lack of a better word....seems to be affecting performance but I haven't checked any temps. I just switched it to emerg. heat and am operating on the furnace right now. Thoughts?
jarrdj is offline   Reply With Quote
Old 02-03-2013, 10:38 AM   #2
AKA HVACTECHFW
Rewards Points: 1,208
installers guide
page 10
Option 345 should be set to 2
option 350 is the balance point.
I would call a pro to check out the noise/compressor operation......
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
jarrdj (02-03-2013)
Configure an add-on radiator as stage 1 heat using a Honeywell thermostat hermhart7 HVAC 10 04-28-2010 06:39 PM
Water Source Heat Pump installation JLMitchell HVAC 6 11-30-2009 04:23 AM
