-   -   Trane Heat Pump tstat replacement with Honeywell prog - wiring question (http://www.diychatroom.com/f17/trane-heat-pump-tstat-replacement-honeywell-prog-wiring-question-4189/)
sep23 10-02-2006 11:05 PM
I want to replace my Trane Weathertron tstat with a Honeywell RTH7400 prog one. I have a Trane heat pump with aux heat. I've been poring over these thread piece-mealing some info the follow is the result.
The old wiring scheme:
X2 - black
O - orange
G - green
Y - yellow
T - tan/brown
R - red
W - white
U - n/a
F - n/a
B - Blue
The honeywell has the following options along with my current wiring in () as see on this forum.
C - (blue)
G - (green)
Y - (yellow)
O/B - (orange)
RC - jumper with R
R - red
AUX - white
E - tan
L - black
Results:
Power runs to the tstat and fan blows on command in manual temp mode but the heat doesn't seem to be produced.
Can anyone cofirm the correct wiring above ?
Thanks in advance,
sep23
sep23 10-03-2006 09:38 PM
Solution
For those interested - Please see this forum for the solutioin to this problem.
#CARRIERMAN 10-20-2006 09:10 PM
Hi sep23
If you have found your answer just trash this, if you havent I can tell you what you need to know.
Rusty
