Trane Heat Pump Not Blowing Cold Or Hot Air - HVAC - DIY Chatroom Home Improvement Forum
Old 08-13-2011, 02:33 PM   #1
Trane Heat Pump not blowing cold or hot air
I live in a condo in a high rise building. My Trane Heat pump just stopped blowing cold and hot air. You can turn the heat up or down on the thermostat and the unit will blow air, it just won't be chilled or heated. The LED diagnostic lights indicate the unit is running fine.
My neighbor said the same thing happened to her, and it was a control board. She said the HVAC tech just bypassed the board until the part came in, and that it worked fine in the interim after he did that.
How do I perform this bypass?
JbIcon is offline   Reply With Quote
Old 08-13-2011, 02:43 PM   #2
You need to determine the actual problem before trying to bypass something.
Master of Cold is offline   Reply With Quote
Old 08-13-2011, 02:56 PM   #3
Thanks for the quick response. Could you give me some direction as where to start? Again, per the LED lights, everything should be OK, no cold or hot air, just ambient.
The other tenants in the building have no problems with their HVAC, as it is a shared system.
Old 08-13-2011, 03:12 PM   #4
JJboy's Avatar
Call hvac tech
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 08-13-2011, 03:18 PM   #5
How would I test this control board?
Old 08-13-2011, 03:26 PM   #6
JJboy's Avatar
Reading the LED lights code.
Old 08-13-2011, 03:30 PM   #7
The LED lights code show operating normal, yet no hot or cold air.
Old 08-13-2011, 03:33 PM   #8
LED1 LED2 LED3
OFF OFF OFF Control OFF
ON OFF OFF Normal/Compressor OFF
ON OFF FLASH Anti-short cycle
ON OFF ON Normal/Compressor ON
FLASH ON OFF Brownout Condition
ON FLASH ON Soft Lockout (low pressure)
ON FLASH FLASH Soft Lockout (high pressure)
ON ON ON Manual Lockout (low pressure)
ON ON FLASH Manual Lockout (high pressure)
ON FLASH OFF Manual Lockout (condensate over-flow)
ON ON OFF Compres sor Disable
Old 08-13-2011, 04:43 PM   #9
An old Tradesmen
Rewards Points: 7,826
Problem could be with the thermostat. Or with the thermostat wires.
Old 08-13-2011, 04:46 PM   #10
What do you mean by this being a shared system?
Old 08-13-2011, 04:53 PM   #11
There is a water chiller on the roof that carries that heated water away from all of the individual heat pumps. Once, when there was a water leak the heat pump did not work. There is no water leak right now, everyone else's HVAC works.
JB
Old 08-13-2011, 07:37 PM   #12
You could have a water valve not opening, or a compressor that wont start.
Old 08-13-2011, 08:07 PM   #13
I think either of those scenarios would trigger a fault code.
Old 11-02-2011, 11:13 AM   #14
I have manual lock out (high pressure)
I am having same problem of no hot or cold air, but my led's are:
ON ON FLASH: Manual Lockout (high pressure)
New batteries on thermostat, yesterday they shut down the coolong towers in my ceiling, later on they were turned on. My neighbors unit is working perfectly but mine is not.
What would be the bypass for this?
JB
jjb305 is offline   Reply With Quote
Old 11-02-2011, 03:24 PM   #15
An old Tradesmen
Turn power off to unit for 1 minute. Then back on, and see if fault clears. If so, it should work ok. If not, look for a manual reset on the high pressure switch in the unit.
Next time you hear they are turning off towers or pumps, turn your unit off. Until they turn tower or pumps back on.
Trane Heat Pump Problems (heat instead of cool) leesimmonds HVAC 12 03-22-2011 04:23 AM
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 12:19 PM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 08:13 PM
Trane EX80 - Blowing Cold Air Thome HVAC 2 10-29-2009 09:57 PM
Trane Heat Pump acting up..frozen (XR13) VEIK HVAC 1 10-20-2008 03:00 PM
