Trane Heat Pump Not Blowing Cold - HVAC - DIY Chatroom Home Improvement Forum
Old 08-31-2009, 10:13 PM   #1
Hi all. Thanks for having me on your forum.
I live in a newer (2 years old) high rise (I'm on the 3rd floor). Recently my Trane heat pump unit stopped blowing cold air. It still blows air, which is slightly cooler than ambient, but not the chill it was before. I opened the unit cover, it had a clog in the condensation drain which kept tripping the sensor and shutting off the compressor. I fixed the clog with bleach. It now runs with the compressor on, and no LED trouble lights. It makes the same hiss when I turn off that it has always made, just no frigid air. Its hot and humid right now in San Diego, help. Thanks
JbIcon is offline   Reply With Quote
Old 09-01-2009, 07:38 AM   #2
If the unit is only 2 years old any parts should be under warranty. Call in a pro who that works on Trane. You may have to pay for labor.
I'm thinking something like low charge due to a leak somewhere. If so, be sure they find and fix the leak instead of gas-and-go. You live in an area rife with A/C ripoffs.
dac122 is offline   Reply With Quote
Old 09-01-2009, 08:47 AM   #3
Have you completely cycled power at the breaker. Some sensors will lock out the unit after it detects a failure. (usually abnormal pressures). This is to protect the system and can only be removed via cycling power or jumpers on the control board.
Before you call in tech, I'd turn power off at the breaker and then back on and see if the system reboots and then returns to normal operation. However if it's in lockout mode the compressor shouldn't run. It's worth a try though.
P.S. I've heard that bleach in the condensate system is a bad idea because the fumes can attack the copper in the evaporator coil.
hennyh is offline   Reply With Quote
Old 09-01-2009, 10:15 AM   #4
Yes, cycled at the breaker. No help. The bleach was just in the drain pipe the leads away from the unit.
trane x19i heat pump MrSnapRon HVAC 8 08-29-2009 01:17 PM
Ductless Heat Pump for Garage?? brittlediabetic HVAC 25 04-23-2009 02:28 PM
Fujitsu Heat Pump Concerns SanDiegoCool HVAC 3 03-19-2009 12:27 PM
How to test apartment Heat Pump tbrubes HVAC 7 02-04-2009 03:05 PM
Trane Heat Pump acting up..frozen (XR13) VEIK HVAC 1 10-20-2008 03:00 PM
