Trane Heat Pump Capacitor Exploded! - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-18-2011, 05:55 PM   #16
Originally Posted by hvactech126 View Post
cc heater is or is not hooked up? compressor could be shorted to ground. if you take one component out of the circuit one at a time you can find out what is shorted. remove the component completely out of the circuit by removing the wiring from the contactor and or capacitor. start with cc heater, then fan, then compressor. are you sure you have everything connected properly? if you have replaced the dual run capacitor (if it uses one) and you hooked the fan and compressor up backwards it could cause the compressor to pull too many amps.
The CC heater is not hooked up (already disconnected by a tech before)
I did have a few techs come out to look at the unit (and could have messed up the wiring).
Do you have a diagram of how they are basically connected? I have three capacitors: run, start + relay, and fan. There is also what looks like a sequencer. I would like to double check the connections if possible. Thanks for your help!
swiffy25 is offline   Reply With Quote
Old 01-18-2011, 06:00 PM   #17
AKA HVACTECHFW
Rewards Points: 1,208
if you are trying to run the heat pump in cold weather and don't have the cc heater in use, you could be slugging the compressor with liquid refrigerant. this would cause the compressor to not operate and the breaker to trip.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 01-18-2011, 11:33 PM   #18
I just connected the CC heater. There is also a wire that leads to a refrigerant line near the compressor as a magnet clip on. Where does this connect to? (contactor?)
Old 01-19-2011, 05:48 AM   #19
AKA HVACTECHFW
that is to be used inline with the cc heater, i believe, to turn the cc heater on as needed
IT IS WHAT IT IS
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 06:53 PM
heat pump question David from MD HVAC 3 02-01-2010 08:42 PM
Heat pump thermostat emergency switch joe913 HVAC 2 12-10-2009 12:54 PM
Heat Pump set back GEAF HVAC 6 01-26-2009 07:49 AM
Trane Heat Pump acting up..frozen (XR13) VEIK HVAC 1 10-20-2008 03:00 PM
