Trane Gas Pack - Advice Needed - HVAC - DIY Chatroom Home Improvement Forum
Old 02-15-2013, 01:36 PM   #1
Trane Gas pack - advice needed
Replacing the goodman 2 ton gas pack :
Choices were Trane , York or Ducane. Based on salesman recommendation Trane is the unit to buy..........
Option 1 is XL14c model- two stage and 14 seer
Option 2 is XB13c model- 13 seer
Price difference installed is $1100. Is it worth spending that amount to get 14 seer and two stage (whatever exactly that does)????? over the 13 seer.
Would I have greater benefits if I were to choose 2.5 tons instead of 2.0 tons also?
Thanks for reading and responses....
cyp555 is offline   Reply With Quote
Old 02-15-2013, 04:46 PM   #2
An old Tradesmen
Rewards Points: 6,140
Call more then one company for estimates.
2 stage is for comfort. may or may not save a lot over a 13 SEER single stage, no way to know.
You might get louder noise from your duct work.
You really need to get quotes from 2 more contractors.
The Following 2 Users Say Thank You to beenthere For This Useful Post:
ben's plumbing (02-15-2013), hvactech126 (02-15-2013)
Old 02-16-2013, 06:41 AM   #3
thanks beenthere....hoping others will chime in with their expert opinions as well....
Old 02-16-2013, 11:43 AM   #4
AKA HVACTECHFW
Rewards Points: 1,208
get more quotes
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Repainting Room With Peeling Paint: Advice Needed Magnetic Painting 8 10-15-2012 06:19 PM
Floating floor water damage - advice needed rumiat Flooring 3 05-28-2012 03:38 PM
Advice needed: Replace corroded fitting to well pipe? lightwolf Plumbing 1 11-30-2011 08:02 PM
Subfloor Overhaul - Advice Needed kadams2345 Flooring 39 11-19-2011 02:02 AM
Forced air and radiant system advice needed jasoncave HVAC 1 01-06-2009 09:46 PM
