Trane Gas Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 10-26-2012, 08:24 AM   #1
Trane Gas Furnace
I just replaced the inducer blower and ignitor switch on our Trane model YCC. We turned the furnace back on to test it and the pilot light comes on and lights the fire. However, the fire quickly goes out and the pilot light then tries to do it's job again by starting the fire and it again goes out. When we further investigated it looks like one of the little fire retardant pieces that is in the tubes beneath where the inducer motor is mounted is gone. We believe this is what is causing our fire to not stay on. If that little piece of fire retardant material has blown to the back of the tube maybe it's possible that it is clogging the way for the fire to breath. I guess my question is does this sound like the problem and what is that part so that I can order it?
bdyost1985 is offline   Reply With Quote
Old 10-26-2012, 12:34 PM   #2
A pic would help about 'little fire retardant pieces'.
Check for exhaust obstructions.
Check flame sensor. Search youtube for 'cleaning flame sensor'. My fav:
. Use emery cloth.
If rubber hose to id fan is frayed at end, disconnect, snip a short piece off and reconnect. If very brittle/dried out, replace. If filled with water, drain hose.
diyorpay is offline   Reply With Quote
Old 10-26-2012, 03:45 PM   #3
An old Tradesmen
Rewards Points: 7,356
Probably just a dirty flame sensor.
Help TRANE XE-80 furnace squeed HVAC 14 12-31-2014 11:29 PM
Trane xb80 gas furnace + trane xl14i diy2000 HVAC 4 08-19-2012 12:08 AM
Trane gas Furnace wiring issue Praetor HVAC 6 08-13-2012 07:31 AM
Trane XE78 Furnace coupled with Trane 1000 AC JND HVAC 3 05-26-2012 03:53 PM
trane furnace problem hcraig4 HVAC 3 04-09-2012 09:33 PM
