Old 01-16-2013, 08:15 AM   #1
Trane Furnace XV80 making tumping noise
Hello all,
I have a Trane XV80 furnace, around 5 years old. The problem, when the furnace is cycling down or shutting off after hitting the desired temp there is a thumping sound coming out of the unit. I pulled the front cover off but that’s it. It’s coming from the inside the unit so its not the duct work. I have uploaded a short video to photo bucket if you have time to look. There is a fan on the front of the unit with a R2 label on it, it shuts off before the sound starts. Any idea what could be causing the sound?
Thanks for your help,
Mark
http://s1339.beta.photobucket.com/us...1c4c3.mp4.html
mwcassedy is offline   Reply With Quote
Old 01-16-2013, 08:38 AM   #2
the link to photobucket was wrong, please try this one.
Old 01-16-2013, 08:57 AM   #3
diy'er
I hear this now and then. In my case it's the air filter after the blower stops. It must get moved up with airflow and once the airflow stops it drops causing a thumping noise.
jvegas is offline   Reply With Quote
Old 01-16-2013, 09:14 AM   #4
Thanks for your reply jvegas. I think we have different issues, my noise is a repetitive thumping that lasts for 60 seconds and sounds like an off balance wheel spinning/banging or a fast firing automatic machine gun. Not the same sound but repetitive until the unit completely shuts off. You can hear the sound on the photobucket viedo I posted.
Old 01-16-2013, 10:39 AM   #5
Roofmaster
You mean that video that last about 4 seconds?
" A lot of men build things, and a lot of things fall down "
Old 01-16-2013, 10:56 AM   #6
Thanks for your response, your comment was less than usefull. The length of the video is dictated by the number of MB they allow. You can hear the sound, despite the short video.
Old 01-16-2013, 11:32 AM   #7
Try to rotate the squirrel cage by hand and feel for anything but smooth. Of COURSE, turn off the power first.
64pvolvo1800 is offline   Reply With Quote
Old 01-16-2013, 02:10 PM   #8
Thank you for your response, I will pull the cover and see what presents itself.
Old 01-16-2013, 07:24 PM   #9
Sounds like the wheel inside the inducer is warped.
Old 01-17-2013, 07:34 AM   #10
Thank you for your response, I will see if that is it.
Trane XV80 & Honeywell IAQ setup greenjp HVAC 9 07-16-2012 07:44 PM
Quote for new furnace. Reasonable? dengle HVAC 16 03-04-2012 08:01 AM
Honeywell stat wiring w/ Trane furnace JaePee HVAC 7 01-18-2009 07:50 AM
Furnace making noise munn HVAC 6 02-08-2007 11:25 PM
Toilet making Noise DSHMSH Plumbing 1 12-22-2005 05:33 PM
