Trane Furnace Works For A Few Hours, Then Burners Will Not Fire - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-16-2012, 01:42 PM   #16
I'm Your Huckleberry
Rewards Points: 2,270
Originally Posted by peacebunny View Post
I checked again...37v, checked multiple times. Furnace is running again now. I also checked the ignitor by unplugging it and putting the leads in the plugs. VM registered 122. When I switched the leads, it didn't register anything. Again, I did it a few times with same results. I followed the ignitor wires to test them at the control board, but I can't get to them. I smell NO gas except right before the burners really do fire, and I have a VERY sensitive nose. If there is gas, I'm smelling it.
You didn't check the ignitor, you checked to see that the control board was sending voltage to the ignitor and yes, it is. Connect your leads to the ignitor leads and OHM it out or test continuity. Then with it plugged back in test amp draw of the ignitor as it's working/glowing. You may need a meter with a clamp that fits around the wire for amp testing. That is how you test the ignitor itself but if it's working then I guess you don't really need to at the moment.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 01-16-2012, 01:46 PM   #17
harleyrider
The technician just mentioned cleaning the flame sensor, nothing else. I was the one who replaced it. Not exactly brain surgery. Are you able to see the other posts I made?
peacebunny is offline   Reply With Quote
Trane XE80 Furnace fan won't stop running Luv2Auction HVAC 2 01-07-2013 10:05 AM
Trane XL80 2-Stage Furnace Won't Fire gregger HVAC 8 01-01-2012 09:54 PM
Ruud Furnace Won't Fire jasonckcmo HVAC 26 12-01-2009 08:55 PM
Trane XE 80 Furnace - flame out and restart Thome HVAC 3 10-12-2009 06:27 PM
Trane xv80 install draft exhaust wires on furnace biggiant HVAC 5 02-10-2009 07:50 PM
