Trane Furnace Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 04-09-2012, 11:13 AM   #1
trane furnace problem
Hi,
I have a trane xb90 furnace which by looking at the red light on the furnace indicates that it is working fine. But I have the thermostat set at 68 and its now around 60 degrees. So I would guess that maybe its the internal circuit board not communicating with the furnace. I had that replaced two years ago. Any thoughts, comments, suggestions would be appreciated
Thank you
hcraig4 is offline   Reply With Quote
Old 04-09-2012, 11:27 AM   #2
how
Rewards Points: 1,104
First, bypass the thermostat as the possible cause by..
turning off the furnace power/ remove the stat wires from their R & W connections in furnace/ jumper R & W connecters together/ turn power back on.
how is online now   Reply With Quote
Old 04-09-2012, 11:58 AM   #3
Thanks, I'll give that a try
Old 04-09-2012, 09:33 PM   #4
Thermostat
Even though the thermostat appeared to be working I put new batteries in it and that did the trick.
Thanks for your help
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Furnace fan won't switch on--unpredictable intermittent problem arvonon HVAC 3 01-22-2012 04:46 PM
Carrier Furnace Problem... cornation71 HVAC 3 12-10-2009 07:52 AM
Trane XE 80 Furnace - flame out and restart Thome HVAC 3 10-12-2009 05:27 PM
LUX digital stat Trane XE80 intermittant problem rossl56 HVAC 6 12-26-2008 05:53 AM
