Trane Excecutive High Efficiency Furnace Help - HVAC - DIY Chatroom Home Improvement Forum
Old 09-01-2009, 07:35 PM   #1
My furnace is from the 80's and... okay this is going to seem like a stupid question, but where the heck is the filter? We can't find it. It makes me worry that we've been going all this time without one installed. Any idea where I could find a manual and diagrams for this?
kashimama is offline   Reply With Quote
Old 09-01-2009, 07:40 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,412
Is the furnace in your basement or attic? If in the basement then it has a return air duct attached to the side of it and the filter should slide in a rack there or be inside the fan compartment (not sure if Trane used that idea). If it is that old you should have a tech check the heat exchanger etc and he can show you the filter.
Old 09-01-2009, 07:46 PM   #3
JohnH1's Avatar
You may also have a single common return with a large wall grill that has the filter behind it. If so it will have small latches to allow the opening of the grill to expose the filter.
JohnH1 is offline   Reply With Quote
New High Efficiency Furnace Problem Buster 567 HVAC 8 12-13-2010 09:36 PM
High efficiency furnace venting Mnrunner HVAC 14 01-18-2009 10:25 PM
venting a high efficiency furnace through the roof (how high) allAboutDIY HVAC 11 10-21-2008 01:48 PM
high efficiency gas furnace hammer6315 General DIY Discussions 2 06-18-2008 11:25 PM
New High Efficiency Gas Furnace & Hot Water Heater frank08226 HVAC 2 04-17-2008 01:06 PM
