TRANE Defrost Control Board Settings? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-17-2011, 12:43 PM   #1
TRANE defrost control board settings?
Can anyone help me identify the defrost cycle switch or jumper settings (30, 45, 90-minute) on the defrost control board? The control board I have is a CNT04695 (same as the CNT4695). Thank you!
TRANEnovice is offline   Reply With Quote
Old 10-17-2011, 05:45 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
That looks like a demand defrost control board.......
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 10-17-2011, 06:00 PM   #3
Thank you hvactech126, yes that is the control board. Any recommendation on interpreting how to distinguish between 30 / 45 / 60-minute settings for frost cycle?
Old 10-17-2011, 06:36 PM   #4
An old Tradesmen
Rewards Points: 7,746
Demand defrost boards don't have a timer.
Old 10-17-2011, 07:01 PM   #5
Without a timer the defrost cycle is fixed. Any idea how many minutes the fixed cycle is for this defrost board?
Old 10-17-2011, 07:23 PM   #6
An old Tradesmen
Its not fixed. It only defrost when when it determines the coil is to frozen/frosted. One day it might do it once every 2 hours, the next once every 3 hours, and below 20 degrees not at all. It will defrost once every 6 hours to make sure the outdoor coil doesn't become oil logged. All times I posted are compressor run times, not just hours of the day.
On demand defrost is the more efficienct way to do defrost, as it doesn't do them needlessly.
Carrier furnace not igniting-bad control board? stick_boy1106 HVAC 4 04-21-2011 06:28 PM
blower control board ferawhile HVAC 0 04-14-2011 10:57 AM
York gas heater control board replacement spyvan HVAC 5 12-29-2008 07:12 AM
Blower control board mlmaher HVAC 1 11-24-2007 01:39 PM
Ruud a/c control board replacement ? kourso HVAC 1 07-20-2006 09:33 PM
