Trane Condensing Unit Keeps Running - HVAC - DIY Chatroom Home Improvement Forum
Old 06-08-2010, 09:26 AM   #1
fastback4's Avatar
Rewards Points: 51
Trane condensing unit keeps running
My trane condensing unit fan keeps running after the cooling cycle has stopped. If i go outside and lift the condensing unit up about 1" and drop it the fan stops. The AC lines outside have ice surrounding it also.
The AC unit will cycle again when needed and maybe or maybe not the condensing unit will keep running......Tom
fastback4 is offline   Reply With Quote
Old 06-08-2010, 06:49 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,856
The magnetic contactor that turns it on/off is probably sticking. Icing it up is VERY BAD for the compressor and can seriously damage it.
What is the price difference between a 2.5 ton unit and a 3 ton unit? Leoskee HVAC 5 06-12-2014 12:00 PM
Time for new condensing unit... ELI(NJ) HVAC 4 11-02-2009 10:37 AM
Trane 1100 XE- Outside unit making humming noise Momof2 HVAC 0 09-03-2009 11:25 AM
AC condensing unit failure? Hotinsummer HVAC 3 08-09-2009 02:08 PM
New Condensing Unit to Match Existing Air Handler? sweaty HVAC 5 03-04-2009 12:37 PM
