Trane CC Part Number - HVAC - DIY Chatroom Home Improvement Forum
Old 03-16-2012, 11:50 AM   #1
Trane CC part number
What is part number for evap coil on Trane XE1000 ac unit #ttr036c100a2?
nevetsnamrok is offline   Reply With Quote
Old 03-16-2012, 01:06 PM   #2
depends on which coil match they gave you.
hvac5646 is offline   Reply With Quote
Old 03-16-2012, 01:58 PM   #3
I have no coil match. I need to purchase a new one without the old one to go by. I am having no luck in finding a part number for the AC coil that sits within the Trane xe80 furnace.
Old 03-16-2012, 02:28 PM   #4
Do you have a Trane ac? If not you must use the model number off your existing ac to match the coil.
Old 03-16-2012, 03:50 PM   #5
I have the Trane AC XE1000 model # TTR036C100A2.
Old 03-16-2012, 07:12 PM   #6
AKA HVACTECHFW
Rewards Points: 1,208
that is a 10 seer a/c. There is no correct match available for it today. I would just get a 3 ton coil that fits the dimensions for on top of your current furnace.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 03-16-2012, 07:49 PM   #7
REP
There is a very good chance that it is an R22 condenser.He has to know that in order to get the right 3 ton coil.
Because it has no coil now he needs to make sure he gets a suction and liquid line filter installed when the coil is installed.
Might also need refrigeration oil and Trane only reccomends their oil be used in their compressors.
This is not as simple as the question makes it sound.
REP is offline   Reply With Quote
Old 03-16-2012, 09:17 PM   #8
Knowing that I need a 3 ton coil helps a lot. I just wish I had a part number to make sure I get the right coil. I thought this would be easy.
Thanks for the help.
Steve
Old 04-04-2012, 05:41 PM   #9
Rewards Points: 77
Ever find coil? Post your furnace model, cannot select based on condenser model.
Filtration / HVAC & Indoor Air Quality Solutions
AirstarFilters is offline   Reply With Quote
Blower Motor for Trane Furnace DocHallie HVAC 4 10-19-2011 04:34 PM
part number for bryant air conditioner capacitors Derricsmama HVAC 2 07-09-2011 09:19 PM
Ducane furnace part number needed mmcgirr HVAC 7 02-13-2011 01:54 AM
Carrier Gas pack Model number peakslayer HVAC 0 01-10-2011 11:02 AM
Need some friendly advice-- Coleman/York v. Trane biggerdaddynj HVAC 3 05-09-2010 10:46 AM
