Old 10-24-2008, 02:46 PM   #1
Trane Carrier XL80 fan runs constantly when switch is on
I have an receptacle in the same outlet as the switch. The outlet was not powered even though it appeared to be wired correctly but the fan was working properly with the switch. My electrician wired the receptacle so it was hot but now the fan runs constantly when the switch is on and we're both stumped. Any ideas on how to wire this thing correctly?
jheavner is offline   Reply With Quote
Old 10-24-2008, 03:06 PM   #2
hvaclover's Avatar
Which one is it Carrier or Trane. They are diff mfgs.
I assume you are talking about the light switch that powers the furnace has a receptacle as a convenience to plug a any electric device into. Yes, no?
Just wiring the outlet out should not cause the fan to run all the time.
Is it heating the house OK? And more importantly were there more wires coming into the switch box from the furnace than just the furnace leads?
Important to know also the model number, is it a 90% or 80% furnace, how old is it?
Just slow, not stupid.
hvaclover is offline   Reply With Quote
Old 10-24-2008, 04:03 PM   #3
The furnace is a Trane XL80. The box on top of it (I'm assuming is the fan/blower) is a Carrier.
Yes, exactly.
The heat was working fine and the fan wasn't blowing all the time until we made the outlet hot. I have a red, black, white, and ground coming from the furnace. We have black going into the receptacle, red going into the top of the switch, white going into the bottom of the switch, and ground is on the ground screw of the switch.
The furnace is an XL80. I don't know what 80% or 90% means. It's less than 5 years old.
Old 10-24-2008, 04:08 PM   #4
hvaclover's Avatar
You have a Trane furnace and a Carrier A/C
Pull all your wire off.
Tell me the color of the wires that come out of the furnace.
Old 10-24-2008, 04:10 PM   #5
Yes, we just found the manuals and are looking for a wiring diagram for the switch but so far just see the thermostat and the actual furnace. What is the red wire for?
Old 10-24-2008, 04:18 PM   #6
hvaclover's Avatar
Is the red white and black wire your supply voltage wires.
And tell me what color the wires come from the furnace are.
Old 10-24-2008, 04:28 PM   #7
hvaclover's Avatar
i can't tell what the red wire is for until I know if its in the supply wiring or the the wiring from the furnace.
If your friend is an electrician he'll be able to answer that question in a snap.
Old 10-24-2008, 04:43 PM   #8
Here are some pics...
Power is coming in from the top. It's old wiring. And the wires you see are coming in from the furnace.
The next picture is zoomed out. The gray wire coming in from the right is the wiring with the red wire.
Old 10-24-2008, 05:01 PM   #9
hvaclover's Avatar
Man that is some shabby workmanship on the wiring. Where does that copper gasline go?
take the powered lead of the incoming wire and connect to the line side of switch and run it to hot side of receptacle.
Take the neutral of the incoming wire and connect to neutral side of receptacle.
Before I can tell you how to proceed I need to know what the red white and black connect to in the furnace.
Usually it's black and white are it but i think that red is hooked into something that needs to be checked.
Old 10-24-2008, 06:37 PM   #10
The previous owners decided they wanted a gas fireplace so they ran a gas line up through the ash chute into the fireplace. There was no cutoff near the fireplace, just the one in the basement that you see in the pic. When we first saw the house our real estate agent told the selling agent that not only was that illegal but likely to end tragically for all involved. What's really scary is the previous owners weren't handy enough to do it themselves so they got someone to do that for them.
That's the problem, I don't know what it's for and the schematics and whatnot for the furnace are well beyond me.
I wired it back to how it was originally so the switch works correctly but the receptacle is cold. The black (power) goes into the bottom of the switch, the black (furnace) goes into the top of the switch, the neutral (power) goes into the top left side of the receptacle, the white (furnace) goes into the bottom left side of the receptacle, and the red (furnace) goes into the right top side of the receptacle.
Old 10-24-2008, 06:41 PM   #11
hvaclover's Avatar
Well good luck.
Old 10-25-2008, 01:02 PM   #12
An old Tradesmen
The recep is probably only suppose to be powered when the blower runs.
It may have been used for a humidifier, or condensate pump.
Old 10-25-2008, 05:14 PM   #13
Yes, it has a humidifier and a Honeywell filter plugged into it.
Old 10-25-2008, 10:54 PM   #14
An old Tradesmen
Then it was wired right before your electrician touched it.
And if he rewired it back to the original way, its correct again.
Its only suppose to be hot when the blower runs.
More On This Topic
Michael Raines, Expert Village. So, let's get right into installing our X10 system. We're going to put in a wall switch. So, let's get to it. This is your everyday wall switch. Semi modern rocker switch, kind of nice but it's not remote control and it's... Read More »
Your swatch pallet in your toolbox has a lot more options. If you look at it, we can see that we have a foreground and background colors already selected here. But I don't like those; I want to go back to black and white. So what I can do is come over... Read More »
Okay. Now do you have all of that down? How to build your capsule wardrobe with your clothing, your accessories, with your scarves, your jewelery, your shoes, your handbags. Now you're probably getting really excited, want to run into the closet and... Read More »
Hi, this is Jon on behalf of Expert Village in this video clip we'll be changing our furnace filter. Now right before winter I always recommend to people to go ahead and change out their old furnace filter with a new one. On this unit our furnace filter... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip I will be showing you how to check your furnace filter. The first thing you need to do is locate your furnace. Now in many houses, the furnace is located in the laundry room which is in the... Read More »
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Trane XE80 (Pressure Switch Indicator Err) cherande HVAC 7 09-25-2008 01:02 AM
Carrier Weathermaster 9200 flame roll-out switch problem jamesbond HVAC 4 12-05-2007 07:55 AM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
