Trane A/c Is Leaking Inside - HVAC - DIY Chatroom Home Improvement Forum
Old 07-17-2011, 11:05 PM   #1
Trane a/c is leaking inside
Our Trane a/c is leaking water under the unit in the house
gauthier4 is offline   Reply With Quote
Old 07-17-2011, 11:09 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
What do mean by in the house? Is this a vertical closet unit or a horizontal attic unit? Furnace or air handler?
Either way, it appears you have a condensate drain backed up.
Pics are always appreciated.
Doc Holliday is offline   Reply With Quote
Old 07-18-2011, 02:09 AM   #3
condensation
I have a trane heat pump and getting condensation from the other unit in my craw space. ah ow to unclog the drain linee
dbertaux is offline   Reply With Quote
Old 07-18-2011, 02:18 AM   #4
condensation from plastic water lines in crawl space
how to correct condensation from plastic water lines running in crawl space
Old 07-18-2011, 07:24 AM   #5
Rewards Points: 1,452
YOu may need to takethe side panels off of the AC unit and trace where the condensate drain line goes.
Leaking Ceiling, Do I Need a Roofer? Phreek Roofing/Siding 31 04-09-2011 04:24 AM
snow getting inside roof turtle vent causing leaking carlstewart Roofing/Siding 5 02-13-2011 03:44 PM
Bathroom Sink Faucet Leaking sgold33 Plumbing 1 01-17-2011 07:16 PM
Leaking toilet/bidet- big problem Trailman Plumbing 11 09-28-2010 05:41 AM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 09:53 PM
