Trane A/C Has A Constanat Leak When The Unit Is On But When I Turn It Off It Stops - HVAC - DIY Chatroom Home Improvement Forum
Old 09-24-2010, 08:51 PM   #1
Trane A/C has a constanat leak when the unit is on but when I turn it off it stops
Trane A/C has a constant leak when the unit is on but when I turn the A/C off it stops.
MBFULTON is offline   Reply With Quote
Old 09-25-2010, 09:35 AM   #2
fabrk8r
fabrk8r's Avatar
Is there any water coming out of the condensate drain line coming from the evaporator case (indoor coil)?
Is the leak from the case itself?
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 09-25-2010, 12:53 PM   #3
Rewards Points: 1,418
All air conditioners condense water at the interior coil during normal operation.
Usually the water is caught in a tray just under the coil but there must be a hose or pipe that drains the water outside or to a nearby sink.
Shower leak (what else) Old home, new owner... Rubbertree Plumbing 8 09-25-2009 02:26 PM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 02:46 PM
why do my 1/4 turn valves leak? moondog111 Plumbing 1 12-08-2008 12:09 AM
Clueless on a/c leak trouble notmrfixit HVAC 3 07-06-2008 10:33 AM
Central heat and air unit leak ? bdalekid HVAC 1 03-21-2007 08:31 AM
