Trane Blower Will Not Shut Off. - HVAC - DIY Chatroom Home Improvement Forum
Old 09-25-2011, 08:40 PM   #1
Trane blower will not shut off.
I have an older train furnace that did work but now the blower will not shut off. HELP!!!
dible62 is offline   Reply With Quote
Old 09-25-2011, 09:17 PM   #2
Rewards Points: 6,652
It is just trying to live up to its namesake of "Nothing runs like a Trane."
Old 09-25-2011, 09:23 PM   #3
Is this a gas or electric furnace?
Is the fan switch, on the thermostat, in the auto position?
Master of Cold is offline   Reply With Quote
Old 09-25-2011, 09:40 PM   #4
how many furnaces do you have? I thought you have a goodman? from other post. check the 3 amp fuse and limits.
Mr.HVAC is offline   Reply With Quote
The Following User Says Thank You to Mr.HVAC For This Useful Post:
dible62 (09-26-2011)
Old 09-26-2011, 05:31 PM   #5
It is a gas furnace & the thermostat is on auto.
Old 09-26-2011, 05:33 PM   #6
The goodman in in my home. The Train is in my rental. Thank you for the help.
Old 09-26-2011, 06:33 PM   #7
Train blower will not shut off.
The only fuse I see is a screw in. It`s by a off & on switch on the side of the frunace. I`m trying to locate the limits.
Old 09-27-2011, 06:20 AM   #8
Rewards Points: 1,216
Sounds like the fan on/off temperature switch is stuck in the closed position keeping the blower on.
COLDIRON is offline   Reply With Quote
The Following User Says Thank You to COLDIRON For This Useful Post:
dible62 (09-27-2011)
Old 09-27-2011, 06:46 AM   #9
Is this a gas furnace, or electric air handler?
Old 09-27-2011, 06:47 AM   #10
If elecric air handler, take the fan relay out and remove the little pc board from the relay, and put the two wires back onto the relay..
The Following User Says Thank You to Master of Cold For This Useful Post:
Old 09-27-2011, 06:01 PM   #11
It is a gas furnace. Thanks!
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 04:39 PM
Trane XL80 blower motor part number? keverino HVAC 17 01-10-2012 09:01 AM
Trane furnace runs even after burners shut off smb2 HVAC 3 01-10-2010 08:16 AM
Trane Furnace Blower Running Nearly Continuously stephensandlin HVAC 3 01-03-2010 01:21 AM
Luxaire furnace blower will not shut off danaugstin HVAC 1 10-06-2009 09:14 PM
