Trane Blower Question - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-07-2010, 03:41 PM   #16
its probably too late but you can always convert that motor to a non variable speed motor just add a relay
kennzz05 is offline   Reply With Quote
Old 07-07-2010, 04:39 PM   #17
Why too late? And how? That was an option, but I didn't have the knowledge to get it done. Thanks again.
HVAC dummy is offline   Reply With Quote
Old 07-08-2010, 04:48 PM   #18
I'm interested! Please speak to me. Thanks
Old 07-11-2010, 02:53 PM   #19
Are you just a tease? Thanks
Old 07-11-2010, 08:47 PM   #20
Y and C to relay coil. EAC terminal hooked to the center post of the relay, normally closed post hooked to cooling speed and normally open post hooked to heating speed. Only works with a standard motor,not a V drive.
Old 07-11-2010, 08:51 PM   #21
An old Tradesmen
Rewards Points: 7,390
So how you controlling the speed, in heating mode. Since its a 2 stage furnace.
Too high of a speed in first stage heat, and you can condensate in the primary heat exchanger. And rot it out.
Too low in second stage, and you over heat the heat exchanger.
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 04:39 PM
Comfortmaker blower intermittent problem jh44ny HVAC 12 07-31-2011 06:41 PM
Trane Filter Cover Question spyder24 HVAC 2 04-04-2010 07:42 AM
Trane XV 90 shuts off burner and exaust blower zootjeff HVAC 0 12-01-2009 11:50 PM
Trane XE80 Heating Question, Please help!!! Stephen1977 HVAC 3 01-30-2007 06:34 PM
