Old 07-05-2010, 07:06 AM   #1
Unhappy
Trane blower question
I have a Trane TUC080B9V3A0 with the variable speed blower. The blower quit while using AC, and the lines to the outside compressor were iced up and the unit still running. Iced up because of no airflow past A coil in plenum?
Blower was removed from furnace. Motor appeared to spin freely, but 10A cartridge fuse in motor control on end of motor was blown. New fuse blew again when fan was set to on at thermostat. There is 115V to the motor controller when trying to run fan from the thermostat.
How do I determine if I should replace the motor, the controller, or both? Is this a DC motor? How do I just check to see if the motor is still OK? Thanks
HVAC dummy is offline   Reply With Quote
Old 07-05-2010, 09:19 AM   #2
An old Tradesmen
Ohm the leads from the motor.
Old 07-05-2010, 09:35 AM   #3
I think there were 4 spade terminals in the connector from the controller to the motor. How are they pinned out? Thanks
Old 07-05-2010, 12:43 PM   #4
An old Tradesmen
Should only be 3 wires from the motor to the module.
Black red green.
Check ohms between each.
Old 07-05-2010, 03:38 PM   #5
Black red green.
There are 5 total in a connector from the module that plugs directly into the motor. 2 brown, and a red, a black, and a blue. There is 4 ohms between the red, black, and blue in any combination of terminals, and there is .5 ohms between the 2 brown. There is no continuity between either brown, and either the black, red, or blue.
Is this a DC motor? I haven't taken the motor out of the 3 legged bracket to try to read a tag on it.
Thanks for any help.
Old 07-05-2010, 05:51 PM   #6
An old Tradesmen
Ok. You don't have a VS blower then. Thats not a DC motor.
Does the one brown wire have a white stripe.
Old 07-05-2010, 07:15 PM   #7
Neither brown wire has a tracer. The schematic on the inside of the blower compartment cover says: integral fan control, variable speed motor. I'm getting warmer, and need my air back! Thanks
Old 07-05-2010, 07:20 PM   #8
An old Tradesmen
How old is your furnace?
Old 07-05-2010, 09:33 PM   #9
I honestly don't know, and I couldn't find any date on the info tag inside the furnace. I don't want it to be time for a new one just yet.
Old 07-05-2010, 09:36 PM   #10
An old Tradesmen
Post serial number.
Yours could be an early version VS. They generally came with a 5 year warranty.
Old 07-05-2010, 11:12 PM   #11
post serial number.
Yours could be an early version vs. They generally came with a 5 year warranty.
d49638140
Old 07-06-2010, 12:03 AM   #12
An old Tradesmen
I think its a 96.
First generation VS. 2.0 version. If its older then that, it real expensive.
Can you post a pic of the motor.
Old 07-06-2010, 09:24 PM   #13
I think its a 96.
I'm having trouble posting pictures, but here's the data from the tag on the motor:
GE ECM model 55ME39HG LX23 S programmable motor
1/2 hp 115V 8A 60hz rpm1100
equip mfrs# C143810P02
Hope this helps. Now that the motor is out of the housing, and the cage is off, the motor seems to be harder to turn. It doesn't spin freely. So it's probably no good? Thanks
Old 07-07-2010, 07:13 AM   #14
An old Tradesmen
VS motor should spin freely. It uses permanent magnets. So it should feel like it has rough bearing when you spin the shaft by hand.
It is more likely that the controller is out.
Trane had a test diagram for that motor. But I don't have a copy of it. You might be able to find a copy floating around on the internet.
Old 07-07-2010, 07:34 AM   #15
Thanks for all of your help. From the info that I have been able to find, I've discovered that the parts are expensive. I think I'm much further ahead by just getting a new furnace this year while I can recoop 30% of the cost with an energy tax credit. I haven't been able to find much info on this furnace online, but if you happen across the test diagram, I'd be interested in seeing it. Thanks again for all of your help.
Bryant Plus 90 - No Blower Ducaticorse HVAC 11 10-16-2012 09:39 PM
Comfortmaker blower intermittent problem jh44ny HVAC 12 07-31-2011 07:41 PM
Trane Filter Cover Question spyder24 HVAC 2 04-04-2010 08:42 AM
Trane XV 90 shuts off burner and exaust blower zootjeff HVAC 0 12-02-2009 12:50 AM
Trane XE80 Heating Question, Please help!!! Stephen1977 HVAC 3 01-30-2007 07:34 PM
